はじめに
This guide shows you how to disassemble and replace the motherboard of your Playstation VR Headset.
必要な工具と部品
Peel back the rubber covering around the lenses to remove the surrounding plastic eyepieces.
Pinch the small white cable connector and unplug it from the motherboard.
The microphone will be attached to the white cable connector on the bottom right of the motherboard.
Remove the two 6mm screws on the L shaped silver clip to the upper left of the motherboard using the Phillips #000 screwdriver.
Remove the one 6mm screw that is securing the silver clip on the far right side using the Phillips #000 screwdriver.
ある他の人がこのガイドを完成しました。
