はじめに
This guide shows you how to disassemble and replace the microphone on your Playstation VR headset.
必要な工具と部品
Peel back the rubber covering around the lenses to remove the surrounding plastic eyepieces.
Pinch the small white cable connector and unplug it from the motherboard.
The microphone will be attached to the white cable connector on the bottom right of the motherboard.
ある他の人がこのガイドを完成しました。
