はじめに
This guide shows you how to disassemble and replace the display on your Playstation VR headset.
必要な工具と部品
Peel back the rubber covering around the lenses to remove the surrounding plastic eyepieces.
Remove the two 6mm screws on the L shaped silver clip to the upper left of the motherboard using the Phillips #000 screwdriver.
Remove the one 6mm screw that is securing the silver clip on the far right side using the Phillips #000 screwdriver.
Press down firmly on the two clips on the sides of the device to remove the display.
2 の人々がこのガイドを完成させました。
