メインコンテンツにスキップ
PlayStation VR Processor Unit Cooling Fan Replacement
必要な工具と部品
  1. PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: 手順 1、 3の画像 1 PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: 手順 1、 3の画像 2 PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: 手順 1、 3の画像 3
    • On one side of the console (the side adjacent to the fan vent), there will be two 6 mm screws. Unscrew them with a PH #000 screwdriver.
  2. PlayStation VR Processor Unit Cooling Fan Replacement: 手順 2、 3の画像 1 PlayStation VR Processor Unit Cooling Fan Replacement: 手順 2、 3の画像 2 PlayStation VR Processor Unit Cooling Fan Replacement: 手順 2、 3の画像 3
    • Press and slide the side panel (it will have the two ports) back to reveal an additional 6 mm screw.
    • Unscrew the 6mm screw with a PH #000 screwdriver.
  3. PlayStation VR Processor Unit Cooling Fan Replacement: 手順 3、 2の画像 1 PlayStation VR Processor Unit Cooling Fan Replacement: 手順 3、 2の画像 2
    • Slide the panel back into place.
  4. PlayStation VR Processor Unit Cooling Fan Replacement: 手順 4、 3の画像 1 PlayStation VR Processor Unit Cooling Fan Replacement: 手順 4、 3の画像 2 PlayStation VR Processor Unit Cooling Fan Replacement: 手順 4、 3の画像 3
    • Using a plastic opening tool, carefully pry the panel from the main console to reveal the HDMI ports.
    • You will probably need to lift it on both sides in order for the panel to come loose.
  5. PlayStation VR Processor Unit Cooling Fan Replacement: 手順 5、 1の画像 1
    • Turn the console over.
    • Unscrew the two 9 mm screws with a PH #000 screwdriver.
  6. PlayStation VR Processor Unit Cooling Fan Replacement: 手順 6、 2の画像 1 PlayStation VR Processor Unit Cooling Fan Replacement: 手順 6、 2の画像 2
    • With the plastic opening tool, carefully pry the console shell panel free and lift it away.
  7. PlayStation VR Processor Unit Cooling Fan Replacement: 手順 7、 2の画像 1 PlayStation VR Processor Unit Cooling Fan Replacement: 手順 7、 2の画像 2
    • Using tweezers, carefully pull the multi colored bundled cable from its port connecting the fan to the console.
    • Carefully lift the fan and its wiring from the device.
    • Be mindful of damaging the wires.
    • Take care to keep your fingers away from the fan blades.
終わりに
8 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Sarah Shand
メンバー登録日: 02/20/17
1,885 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team S3-G1, Sullivan Spring 2017 USF Tampa, Team S3-G1, Sullivan Spring 2017人のメンバー
USFT-SULLIVAN-S17S3G1
3 メンバー
13のガイドは作成済み
4 件のコメント
Where do I get a replacement fan tho?
Ponos King - 返信
I think is a 3x3 cm fan, alliexpres has some, but what voltage?
crus - 返信
5V is what i have read
Ethan Amos -
Reference for fan when I have replaced mine : DELTA ELECTRONICS MODEL : ASB0305MA-01 DC 5V 0.19A
herossuperman - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 45
今までの合計 8,710
