メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
If your PlayStation is having trouble reading discs, the optical drive may need to be replaced. The optical drive is prone to fail on earlier models due to plastic rails warping over time. This guide will take you through the process of replacing the optical drive, which includes the laser and motor assemblies.
Note: This repair is demonstrated on a SCPH-1001 model. The process may differ slightly if you have a later model.
パーツ
パーツは指定されていません。
  1. Before you begin, make sure the console is turned off and unplugged.
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
    The SCPH-9001 model does not have the Parallel Port panel to remove.
    Aislinn - 返信
  2. While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it. While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
  3. Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it. Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it.
    • Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it.
    I broke the optical drive power cable’s socket off from the motherboard! How to put it back on?
    B H - 返信
  4. Use the flat end of a spudger to lift up and unlock one side of the data cable's connector on the motherboard. Repeat this step on the other side of the connector. You'll hear a faint click noise when unlocking the connector. Make sure not to apply too much pressure when lifting up on the connector with the spudger, or else damage may result. Gently pull the optical drive data cable straight up and out of its socket on the motherboard to disconnect it.
    • Use the flat end of a spudger to lift up and unlock one side of the data cable's connector on the motherboard. Repeat this step on the other side of the connector.
    • You'll hear a faint click noise when unlocking the connector. Make sure not to apply too much pressure when lifting up on the connector with the spudger, or else damage may result.
    • Gently pull the optical drive data cable straight up and out of its socket on the motherboard to disconnect it.
    While I was pulling this cable, the whole connector came off the motherboard (the white part that's supposed do stay on the motherboard)... How can I fix it?
    Zvezdan Disic - 返信
    Do I solder it or what?
    Zvezdan Disic - 返信
    Same exact problem with pulling the entire connector off the motherboard. What do i do?
    Aaron Loyd - 返信
    Yes, could try clean and re-solder, and do a proper re-work job.
    Leif Behrmann - 返信
  5. Lift the optical drive straight up to remove it. Lift the optical drive straight up to remove it.
    • Lift the optical drive straight up to remove it.
終わりに
37 の人々がこのガイドを完成させました。
Craig Lloyd
メンバー登録日: 2016年02月10日
12,498 ポイント
64のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
129 メンバー
12,970のガイドは作成済み
2 件のコメント
Laser Drive Models
SCPH-100x : KSM-440AAM and KSM-440ACM
SCPH-550x-700x : KSM-440ADM
SCPH-750x-900x : KSM-440AEM
SCPH-10x : KSM-440BAM
Chances are most, if not all of the original AAM and ACM lasers are worn out.
Some vendors still carry an supposed original KSM-440BAM laser unit only.
I could not make this laser work in a SCPH-1001 unit, even after the transfer of parts.
I heard a rumor of spacers and motherboard adjustment.
This: https://web.archive.org/web/201010090109...
PU-8 test point: CL708, voltage reading to ground without disk - 1.7 volts DC, voltage reading with disk 1.85 volts DC.
Very fine adjustment… I have yet to try this step. Has anyone?
What about spacers? Do I need these?
You must transfer the rubber grommets and the plastic laser cover from the old laser to the new.
If you don’t, the new laser will be too large for the SCPH-1001 chassis.
Leif Behrmann - 返信
What about model SCPH-5501?
janis Nasuta - 返信
コメントを追加
統計データを表示:
過去 24時間: 12
過去 7 日: 46
過去 30 日: 298
今までの合計 45,078
