メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
パーツ
パーツは指定されていません。
  1. Remove all cables plugged into the PlayStation.
    • Remove all cables plugged into the PlayStation.
  2. Flip over the PlayStation and remove the six screws from the bottom. Flip over the PlayStation and remove the six screws from the bottom.
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. Flip the PlayStation back.
    • Flip the PlayStation back.
    • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
  4. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  5. Lift up and remove the upper case. Lift up and remove the upper case.
    • Lift up and remove the upper case.
  6. Disconnect the cables from the PSone’s board. Take extreme care when disconnecting the ribbon cable from motherboard. You risk damaging the cable if you’re not careful. Take extreme care when disconnecting the ribbon cable from motherboard. You risk damaging the cable if you’re not careful.
    • Disconnect the cables from the PSone’s board.
    • Take extreme care when disconnecting the ribbon cable from motherboard. You risk damaging the cable if you’re not careful.
  7. remove the metal plate remove the metal plate
    • remove the metal plate
  8. remove the mother board by lifting the back. if you're having a hard time removing it, use your nail and lift the second controller port. if you're having a hard time removing it, use your nail and lift the second controller port.
    • remove the mother board by lifting the back.
    • if you're having a hard time removing it, use your nail and lift the second controller port.
  9. Remove the metal case. Remove the metal case.
    • Remove the metal case.
終わりに
3 の人々がこのガイドを完成させました。
trickster
メンバー登録日: 2013年12月23日
1,992 ポイント
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 27
今までの合計 2,022
