メインコンテンツにスキップ
はじめに
The rumble motor is the device that allows the move controller to vibrate. This guide will help you replace it if it is broken or damaged.
  1. Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver. Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver.
    • Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver.
  2. Pinch the sides of the back panel to remove it and set it aside. Pinch the sides of the back panel to remove it and set it aside. Pinch the sides of the back panel to remove it and set it aside.
    • Pinch the sides of the back panel to remove it and set it aside.
  3. Hold the base of the controller with one hand and with the other carefully pull up on the white spherical piece to remove it. Hold the base of the controller with one hand and with the other carefully pull up on the white spherical piece to remove it.
    • Hold the base of the controller with one hand and with the other carefully pull up on the white spherical piece to remove it.
  4. Push the Lithium Ion battery from its slot to remove it. Be mindful not to damage the wires or wired components, as the battery will still be attached via its connector.
    • Push the Lithium Ion battery from its slot to remove it.
    • Be mindful not to damage the wires or wired components, as the battery will still be attached via its connector.
  5. Unscrew the 9mm screw in the battery slot with a PH #00 screwdriver.
    • Unscrew the 9mm screw in the battery slot with a PH #00 screwdriver.
  6. Using a plastic opening tool, carefully pry the rumble motor free. Using a plastic opening tool, carefully pry the rumble motor free.
    • Using a plastic opening tool, carefully pry the rumble motor free.
  7. Unscrew the 9mm screw behind the rumble motor slot with a PH #00 screwdriver.
    • Unscrew the 9mm screw behind the rumble motor slot with a PH #00 screwdriver.
  8. Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller. Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller. Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller.
    • Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller.
  9. Using your fingers, carefully pry the square green piece beneath the battery slot free. It is attached via white ribbons which need to be kept intact.
    • Using your fingers, carefully pry the square green piece beneath the battery slot free.
    • It is attached via white ribbons which need to be kept intact.
  10. Follow the white ribbon attached to the part you just removed to a smaller, more rectangular piece. Lift the rectangular piece from its slot to free it. Lift the rectangular piece from its slot to free it.
    • Follow the white ribbon attached to the part you just removed to a smaller, more rectangular piece.
    • Lift the rectangular piece from its slot to free it.
  11. Carefully lift the entire circuit board from the black plastic encasing it. Take extra care not to damage any of the wired components. Take extra care not to damage any of the wired components.
    • Carefully lift the entire circuit board from the black plastic encasing it.
    • Take extra care not to damage any of the wired components.
  12. Using a soldering iron, carefully desolder the wires from the board. For help with desoldering, please check out this guide: How To Solder and Desolder Connections
    • Using a soldering iron, carefully desolder the wires from the board. For help with desoldering, please check out this guide: How To Solder and Desolder Connections
    • In order to install the new rumble motor, you must solder the wires of the new motor to the circuit board.
終わりに
Sarah Shand
メンバー登録日: 2017年02月20日
1,536 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team S3-G1, Sullivan Spring 2017 USF Tampa, Team S3-G1, Sullivan Spring 2017人のメンバー
USFT-SULLIVAN-S17S3G1
3 メンバー
13のガイドは作成済み
コメント1件
Step 7, there are 2 screws at the top near the white spherical piece holding the PCB on place that also need to be removed before you can lift it out
Steve Massart - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 1,036
