メインコンテンツにスキップ
PlayStation Move LED Light Replacement
必要な工具と部品
  1. PlayStation Move LED Light Replacement, Battery: 手順 1、 3の画像 1 PlayStation Move LED Light Replacement, Battery: 手順 1、 3の画像 2 PlayStation Move LED Light Replacement, Battery: 手順 1、 3の画像 3
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
  2. PlayStation Move LED Light Replacement: 手順 2、 2の画像 1 PlayStation Move LED Light Replacement: 手順 2、 2の画像 2
    • Insert the plastic opening tool at the indent.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Using your hands to further pull it apart.
  3. PlayStation Move LED Light Replacement: 手順 3、 2の画像 1 PlayStation Move LED Light Replacement: 手順 3、 2の画像 2
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
    You can disconnect the back/trigger assembly ribbon cable at this point by proceeding to Steps 13/14 (without the other steps for disassembly as they are unnecessary for replacing just the trigger).
    Peter Miller - 返信
  4. PlayStation Move LED Light Replacement: 手順 4、 3の画像 1 PlayStation Move LED Light Replacement: 手順 4、 3の画像 2 PlayStation Move LED Light Replacement: 手順 4、 3の画像 3
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
  5. PlayStation Move LED Light Replacement: 手順 5、 2の画像 1 PlayStation Move LED Light Replacement: 手順 5、 2の画像 2
    • Gently pull out the small grey cylindrical piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
  6. PlayStation Move LED Light Replacement: 手順 6、 2の画像 1 PlayStation Move LED Light Replacement: 手順 6、 2の画像 2
    • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
  7. PlayStation Move LED Light Replacement: 手順 7、 3の画像 1 PlayStation Move LED Light Replacement: 手順 7、 3の画像 2 PlayStation Move LED Light Replacement: 手順 7、 3の画像 3
    • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
    • Remove by squeezing the inner plastic frame, lift and pull it towards you.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
  8. PlayStation Move LED Light Replacement: 手順 8、 2の画像 1 PlayStation Move LED Light Replacement: 手順 8、 2の画像 2
    • Gently pull on the white piece connecting the battery and the connector.
  9. PlayStation Move LED Light Replacement, Motherboard: 手順 9、 3の画像 1 PlayStation Move LED Light Replacement, Motherboard: 手順 9、 3の画像 2 PlayStation Move LED Light Replacement, Motherboard: 手順 9、 3の画像 3
    • Remove the five 1.2 mm screws from upper portion of the controller.
    • If you are replacing the trigger button, continue to step 13.
  10. PlayStation Move LED Light Replacement: 手順 10、 2の画像 1 PlayStation Move LED Light Replacement: 手順 10、 2の画像 2
    • Remove the two 1.2mm Phillips #1 screws.
  11. PlayStation Move LED Light Replacement: 手順 11、 3の画像 1 PlayStation Move LED Light Replacement: 手順 11、 3の画像 2 PlayStation Move LED Light Replacement: 手順 11、 3の画像 3
    • Cautiously remove the circular white piece at the top without removing the LED inside.
    Accidentally ripped this off as my PS Move is a different model, any chance this could be fixed using like jumper wires or not?
    Alex Flint - 返信
  12. PlayStation Move LED Light Replacement: 手順 12、 3の画像 1 PlayStation Move LED Light Replacement: 手順 12、 3の画像 2 PlayStation Move LED Light Replacement: 手順 12、 3の画像 3
    • Remove the blue strip that is connected to the trigger button from the motherboard.
    • Be careful to gently detach it from the motherboard. The strip may rip if too much strength is applied.
  13. PlayStation Move LED Light Replacement: 手順 13、 2の画像 1 PlayStation Move LED Light Replacement: 手順 13、 2の画像 2
    • Remove the trigger button from the controller.
  14. PlayStation Move LED Light Replacement: 手順 14、 3の画像 1 PlayStation Move LED Light Replacement: 手順 14、 3の画像 2 PlayStation Move LED Light Replacement: 手順 14、 3の画像 3
    • Remove the LED light by removing the white strip.
    • If you are replacing the LED light, continue to Step 17.
    This step is destructive and simply breaks the LED solder joints!!!
    Peter Miller - 返信
    WTF, you literally broke the soldered ribbon cable.
    fastasleep - 返信
  15. PlayStation Move LED Light Replacement: 手順 15、 2の画像 1 PlayStation Move LED Light Replacement: 手順 15、 2の画像 2
    • Remove the motherboard from the plastic case.
  16. PlayStation Move LED Light Replacement, LED Light: 手順 16、 2の画像 1 PlayStation Move LED Light Replacement, LED Light: 手順 16、 2の画像 2
    • Insert tweezers between the LED case and the LED clear plastic cover.
    • Lift the edge of the LED clear cover clip to be able to remove the cover.
    • Repeat the previous step to the other side.
    • Remove the LED cover.
  17. PlayStation Move LED Light Replacement: 手順 17、 2の画像 1 PlayStation Move LED Light Replacement: 手順 17、 2の画像 2
    • Remove the LED board using a blue opening tool to lift the board.
    • After the board is loose, remove the LED board.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Maritza Martinez
メンバー登録日: 09/28/16
149 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 3-3, Passmore Fall 2016 USF Tampa, Team 3-3, Passmore Fall 2016人のメンバー
USFT-PASSMORE-F16S3G3
4 メンバー
8のガイドは作成済み
3 件のコメント
Okay, going to try this. Do I have to solder the white strip back onto the board?
randallrigdonjr - 返信
did you ever get this done? need to know the same.
[deleted] -
très clair, mais où trouver une led ? et en enlevant le cable de la led, il faut le dessourder, non ?
Pierrot - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 24
今までの合計 4,161
