メインコンテンツにスキップ
はじめに
This is a prerequisite guide that will show you how to disassemble the PlayStation Move controller.
パーツ
パーツは指定されていません。
  1. Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver. Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver.
    • Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver.
  2. Pinch the sides of the back panel to remove it and set it aside. Pinch the sides of the back panel to remove it and set it aside. Pinch the sides of the back panel to remove it and set it aside.
    • Pinch the sides of the back panel to remove it and set it aside.
  3. Hold the base of the controller with one hand and with the other carefully pull up on the white spherical piece to remove it. Hold the base of the controller with one hand and with the other carefully pull up on the white spherical piece to remove it.
    • Hold the base of the controller with one hand and with the other carefully pull up on the white spherical piece to remove it.
  4. Push the Lithium Ion battery from its slot to remove it. Be mindful not to damage the wires or wired components, as the battery will still be attached via its connector.
    • Push the Lithium Ion battery from its slot to remove it.
    • Be mindful not to damage the wires or wired components, as the battery will still be attached via its connector.
  5. Unscrew the 9mm screw in the battery slot with a PH #00 screwdriver.
    • Unscrew the 9mm screw in the battery slot with a PH #00 screwdriver.
  6. Using a plastic opening tool, carefully pry the rumble motor free. Using a plastic opening tool, carefully pry the rumble motor free.
    • Using a plastic opening tool, carefully pry the rumble motor free.
  7. Unscrew the 9mm screw behind the rumble motor slot with a PH #00 screwdriver.
    • Unscrew the 9mm screw behind the rumble motor slot with a PH #00 screwdriver.
  8. Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller. Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller. Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller.
    • Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller.
  9. Using your fingers, carefully pry the square green piece beneath the battery slot free. It is attached via white ribbons which need to be kept intact.
    • Using your fingers, carefully pry the square green piece beneath the battery slot free.
    • It is attached via white ribbons which need to be kept intact.
  10. Follow the white ribbon attached to the part you just removed to a smaller, more rectangular piece. Lift the rectangular piece from its slot to free it. Lift the rectangular piece from its slot to free it.
    • Follow the white ribbon attached to the part you just removed to a smaller, more rectangular piece.
    • Lift the rectangular piece from its slot to free it.
  11. Carefully lift the entire circuit board from the black plastic encasing it. Take extra care not to damage any of the wired components. Take extra care not to damage any of the wired components.
    • Carefully lift the entire circuit board from the black plastic encasing it.
    • Take extra care not to damage any of the wired components.
終わりに
Sarah Shand
メンバー登録日: 2017年02月20日
1,617 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team S3-G1, Sullivan Spring 2017 USF Tampa, Team S3-G1, Sullivan Spring 2017人のメンバー
USFT-SULLIVAN-S17S3G1
3 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 73
