はじめに
If your PlayStation is displaying faulty video, emitting choppy audio, or just isn’t booting properly, the motherboard may need to be replaced. This guide will take you through the process of replacing the motherboard, which houses all of the processors and A/V connectors.
Note: This repair is demonstrated on a SCPH-1001 model. The process may differ slightly if you have a later model.
必要な工具と部品
Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
Remove five Phillips #1 screws securing the metal shield to the controller ports:
Two 14 mm screws
Three 8 mm screws
Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it.
Pull the power supply cable straight up and out of its socket on the motherboard to disconnect it.
Remove the five 14 mm-long Phillips #1 screws from the motherboard's metal shield.
Remove the three 14 mm-long Phillips #1 screws securing the motherboard to the bottom case.
27 の人々がこのガイドを完成させました。
2 件のコメント
Excelente guía, esto ayuda a muchos para aprender a reparar y no hacer gastos innecesarios.
