はじめに
This will guide you through the process of replacing your logic board.
必要な工具と部品
Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it.
With one hand, hold the main board’s protective metal cover. With your other hand, wedge the spudger in between the right side of the protective cover and the thin metal clamps that surround it.
With the spudger in place, gently lift the upper portion of the metal cover. The cover should detach from the right side.
27 の人々がこのガイドを完成させました。
2 件のコメント
Excelente guía, esto ayuda a muchos para aprender a reparar y no hacer gastos innecesarios.
