ガイド紹介
This will guide you through the process of replacing your logic board.
パーツ
パーツは指定されていません。
  1. Remove the parallel port cover on the back of the PlayStation.
    • Remove the parallel port cover on the back of the PlayStation.
  2. Flip over the PlayStation and remove the six screws from the bottom.
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. Turn the PlayStation upright. Remove the cover by lifting it up.
    • Turn the PlayStation upright. Remove the cover by lifting it up.
  4. Carefully disconnect the gold-colored ribbon cable from it's connector.
    • Carefully disconnect the gold-colored ribbon cable from it's connector.
    • To avoid damaging the cable, pull it by the white, reinforced tab.
  5. Disconnect the second cable by pulling up on the plastic connector at the end.
    • Disconnect the second cable by pulling up on the plastic connector at the end.
  6. Android 修理キット
    交換用スクリーンやバッテリーの修理キット
    ショップを見る
    Android 修理キット
    ショップを見る
  7. Lift the optical drive off of the PlayStation.
    • Lift the optical drive off of the PlayStation.
  8. Remove the four screws from the logic board's metal cover.
    • Remove the four screws from the logic board's metal cover.
  9. Detach power supply connector from logic board by pulling on the plastic tab.
    • Detach power supply connector from logic board by pulling on the plastic tab.
  10. Detach white ribbon cable from logic board by gently lifting on it.
    • Detach white ribbon cable from logic board by gently lifting on it.
  11. With one hand, hold the main board’s protective metal cover. With your other hand, wedge the spudger in between the right side of the protective cover and the thin metal clamps that surround it.
    • With one hand, hold the main board’s protective metal cover. With your other hand, wedge the spudger in between the right side of the protective cover and the thin metal clamps that surround it.
    • With the spudger in place, gently lift the upper portion of the metal cover. The cover should detach from the right side.
  12. Using the same process from the previous step, wedge the spudger between the clamps and metal cover on the bottom side (as shown in the picture).
    • Using the same process from the previous step, wedge the spudger between the clamps and metal cover on the bottom side (as shown in the picture).
    • With your other hand, pull up on the top right corner of the metal cover to lift it off.
  13. Remove the last four screws from the logic board.
    • Remove the last four screws from the logic board.
  14. Lift the logic board out of the PlayStation and replace with a new logic board.
    • Lift the logic board out of the PlayStation and replace with a new logic board.
終わりに
13 の人々がこのガイドを完成させました。
JakeDeschamps
メンバー登録日: 2009年10月28日
1,065 Reputation
5のガイドは作成済み
Cal Poly, Team 5-2, Regan Fall 2009 Cal Poly, Team 5-2, Regan Fall 2009人のメンバー
CPSU-REGAN-F09S5G2
5 メンバー
14のガイドは作成済み
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 61
All Time: 18,849
