メインコンテンツにスキップ
PlayStation 4 Wi-Fi Antenna Replacement
必要な工具と部品
  1. PlayStation 4 Wi-Fi Antenna Replacement, Flip over the PS4: 手順 1、 1の画像 1
    • Flip the PS4 upside-down with the back side facing towards you.
  2. PlayStation 4 Wi-Fi Antenna Replacement, Remove the warranty stickers: 手順 2、 3の画像 1 PlayStation 4 Wi-Fi Antenna Replacement, Remove the warranty stickers: 手順 2、 3の画像 2 PlayStation 4 Wi-Fi Antenna Replacement, Remove the warranty stickers: 手順 2、 3の画像 3
    • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
  3. PlayStation 4 Wi-Fi Antenna Replacement, Remove the plastic screw covers: 手順 3、 2の画像 1 PlayStation 4 Wi-Fi Antenna Replacement, Remove the plastic screw covers: 手順 3、 2の画像 2
    • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
  4. PlayStation 4 Wi-Fi Antenna Replacement, Remove the rear case screws: 手順 4、 2の画像 1 PlayStation 4 Wi-Fi Antenna Replacement, Remove the rear case screws: 手順 4、 2の画像 2
    • Remove the four 7.2 mm Torx security screws on the back of the PS4.
  5. PlayStation 4 Wi-Fi Antenna Replacement, Remove the lower case: 手順 5、 2の画像 1 PlayStation 4 Wi-Fi Antenna Replacement, Remove the lower case: 手順 5、 2の画像 2
    • Use your thumbs to lift the lower case up and off the PS4.
    • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
  6. PlayStation 4 Wi-Fi Antenna Replacement: 手順 6、 2の画像 1 PlayStation 4 Wi-Fi Antenna Replacement: 手順 6、 2の画像 2
    • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
    • If your connector feels stuck, use a spudger to gently pry the connector out.
  7. PlayStation 4 Wi-Fi Antenna Replacement, Remove the power supply unit: 手順 7、 2の画像 1 PlayStation 4 Wi-Fi Antenna Replacement, Remove the power supply unit: 手順 7、 2の画像 2
    • Remove three 9.7 mm Torx security screws.
    • Remove two 41 mm Phillips screws and brackets.
  8. PlayStation 4 Wi-Fi Antenna Replacement: 手順 8、 3の画像 1 PlayStation 4 Wi-Fi Antenna Replacement: 手順 8、 3の画像 2 PlayStation 4 Wi-Fi Antenna Replacement: 手順 8、 3の画像 3
    • Lift the power supply straight up and out of the PS4.
    • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it.
    • During reassembly, ensure the prongs are aligned, then press the power supply into place.
  9. PlayStation 4 Wi-Fi Antenna Replacement, Remove the Wi-Fi antenna: 手順 9、 2の画像 1 PlayStation 4 Wi-Fi Antenna Replacement, Remove the Wi-Fi antenna: 手順 9、 2の画像 2
    • Use the tip of a spudger to disconnect the antenna cable from the motherboard.
  10. PlayStation 4 Wi-Fi Antenna Replacement: 手順 10、 3の画像 1 PlayStation 4 Wi-Fi Antenna Replacement: 手順 10、 3の画像 2 PlayStation 4 Wi-Fi Antenna Replacement: 手順 10、 3の画像 3
    • Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
  11. PlayStation 4 Wi-Fi Antenna Replacement: 手順 11、 3の画像 1 PlayStation 4 Wi-Fi Antenna Replacement: 手順 11、 3の画像 2 PlayStation 4 Wi-Fi Antenna Replacement: 手順 11、 3の画像 3
    • Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
  12. PlayStation 4 Wi-Fi Antenna Replacement: 手順 12、 2の画像 1 PlayStation 4 Wi-Fi Antenna Replacement: 手順 12、 2の画像 2
    • Remove the 9.7 mm Torx security screw securing the antenna.
  13. PlayStation 4 Wi-Fi Antenna Replacement: 手順 13、 2の画像 1 PlayStation 4 Wi-Fi Antenna Replacement: 手順 13、 2の画像 2
    • Remove the Wi-Fi antenna.
終わりに
89 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Sam Omiotek
メンバー登録日: 02/25/19
72,830 ポイント
288のガイドは作成済み
111 件のコメント
Took me about 10mins with this guide. Super easy. New parts in and working wonderfully. Ty ifixit!
luckycha87 - 返信
My wireless controlers wasn't recognised. I change the WiFi connector but this problem is not resoleved yet.
Frederic Morelli - 返信
Hi Frederic! Have you tried resetting the controller? Have you tried any other controllers to see if they work? Also, are you sure the battery in your controller is good and it's charged up?
TronicsFix -
Hello my controller has a hard time working from 4 feet away from my console and disconnecting. Im thinking of doing this hopefully it works. Is the bluetooth and wifi part the same thing because my wifi doesnt seem to pick up my wireless router.
ludracing - 返信
Yes, the wifi and bluetooth antenna is the same.
TronicsFix -
コメントを追加
統計データ:
過去 24時間: 32
過去 7 日: 242
過去 30 日: 1,121
今までの合計 165,083
