メインコンテンツにスキップ
はじめに
Consoles such as the PlayStation 4 Slim over time start to overheat from all the excessive dust accumulating. It causes the thermal paste to thin out and the speed drastically reduces. The overheating produces noise and users no longer want the console because of this some are even willing to replace it. This guide shows how to clean PlayStation 4 Slim, replace the thermal paste, and restore the console to fantastic working conditions!
ビデオの概要
  1. PlayStation 4 Slim Thermal Paste Replacement, Thermal Paste: 手順 1、 2の画像 1 PlayStation 4 Slim Thermal Paste Replacement, Thermal Paste: 手順 1、 2の画像 2
    • Remove the panel next to the ports by sliding it to the right.
    • Use a T9 Torx security screwdriver to remove the screw.
    That’s clearly a Phillips screw… not Torx.
    Andrew Sauk - 返信
  2. PlayStation 4 Slim Thermal Paste Replacement: 手順 2、 1の画像 1
    • Pull the black ribbon on the side of the PS4 to remove the hard drive.
  3. PlayStation 4 Slim Thermal Paste Replacement: 手順 3、 1の画像 1
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Peel off the plastic warranty sticker next to the three ports on the side of the console.
    Bei mir war es der TR8 Schraubendreher
    Tim Krauthoff - 返信
  4. PlayStation 4 Slim Thermal Paste Replacement: 手順 4、 2の画像 1 PlayStation 4 Slim Thermal Paste Replacement: 手順 4、 2の画像 2
    • Flip the PS4 with the bottom side facing upwards and the side of the screw you just removed facing you.
    • Remove the cover by prying the two corners and then sliding it back.
    • This step will require some force and you will hear clicking sounds as the cover is coming off.
  5. PlayStation 4 Slim Thermal Paste Replacement: 手順 5、 1の画像 1
    • Use a Phillips #0 screwdriver to remove this screw.
  6. PlayStation 4 Slim Thermal Paste Replacement: 手順 6、 3の画像 1 PlayStation 4 Slim Thermal Paste Replacement: 手順 6、 3の画像 2 PlayStation 4 Slim Thermal Paste Replacement: 手順 6、 3の画像 3
    • Remove the three T9 Torx security screws.
    • Use a Phillips #0 screwdriver to remove the two screws.
    • Lift and remove the metal panel after unscrewing.
  7. PlayStation 4 Slim Thermal Paste Replacement: 手順 7、 1の画像 1
    • Remove the power supply completely by disconnecting the wire.
  8. PlayStation 4 Slim Thermal Paste Replacement: 手順 8、 3の画像 1 PlayStation 4 Slim Thermal Paste Replacement: 手順 8、 3の画像 2 PlayStation 4 Slim Thermal Paste Replacement: 手順 8、 3の画像 3
    • Flip the PS4 to view the metal paneling.
    • Lift the black clip on the largest connection to remove it.
    • Disconnect the wire by pulling it back with a little bit of force.
    • By pulling on the blue tabs gently you are able to remove the connections.
    • Gently lift the black wire to disconnect from the motherboard.
  9. PlayStation 4 Slim Thermal Paste Replacement: 手順 9、 2の画像 1 PlayStation 4 Slim Thermal Paste Replacement: 手順 9、 2の画像 2
    • Use a Phillips #0 screwdriver to remove all screws.
    • After unscrewing, remove the metal panel to access the motherboard.
    • Removing the metal panel may require some force but do not pull up too hard as you may have missed a screw.
  10. PlayStation 4 Slim Thermal Paste Replacement: 手順 10、 2の画像 1 PlayStation 4 Slim Thermal Paste Replacement: 手順 10、 2の画像 2
    • Use a Phillips #0 screwdriver to remove two screws.
    • Unplug the wire by pulling firmly.
    • Lift the metal brace with your fingers to expose the motherboard.
  11. PlayStation 4 Slim Thermal Paste Replacement: 手順 11、 2の画像 1 PlayStation 4 Slim Thermal Paste Replacement: 手順 11、 2の画像 2
    • Apply 2-3 droplets of thermal material remover on Q-tips to remove the old thermal paste and then wipe it down with a micro fiber cloth until no residue of old paste is left.
    • Apply 2-3 droplets of thermal surface purifier on a new Q-tip and go over the area cleaned.
    • Both steps may require multiple repetitions.
    thank you as always for the pictures but there should be a warning or notice added in there is a very small bracket on the heatsink itself it fell off when i removed the heatsink i could not find out where it belonged until i saw these pictures it look like a u shape with a small screw hole in the middle.
    ccarter314 - 返信
  12. PlayStation 4 Slim Thermal Paste Replacement: 手順 12、 2の画像 1 PlayStation 4 Slim Thermal Paste Replacement: 手順 12、 2の画像 2
    • Squeeze about 3/4 of an inch of Arctic Silver 5 thermal paste onto the prepared surface.
    • Let the thermal paste rest for 10 minutes before reassembly.
  13. PlayStation 4 Slim Thermal Paste Replacement: 手順 13、 1の画像 1
  14. PlayStation 4 Slim Thermal Paste Replacement: 手順 14、 2の画像 1 PlayStation 4 Slim Thermal Paste Replacement: 手順 14、 2の画像 2
    • Flip the console.
    • Use a Phillips #0 screwdriver to remove the screw.
  15. PlayStation 4 Slim Thermal Paste Replacement: 手順 15、 2の画像 1 PlayStation 4 Slim Thermal Paste Replacement: 手順 15、 2の画像 2
    • Lift up the metal panel and on the back the radiator is located.
    • Clean the radiator by using a brush and a compressed air can.
  16. PlayStation 4 Slim Thermal Paste Replacement: 手順 16、 2の画像 1 PlayStation 4 Slim Thermal Paste Replacement: 手順 16、 2の画像 2
    • Clean the fan by using a brush and a compressed air can.
終わりに
34 の人々がこのガイドを完成させました。
Muhammad Saif Khan
メンバー登録日: 2020年07月07日
1,222 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G7, Allen Summer 2020 York University, Team S1-G7, Allen Summer 2020人のメンバー
YORK-ALLEN-SU20S1G7
1 メンバー
5のガイドは作成済み
3 件のコメント
Hey, can I use this for a original “fat” ps4?
thanks
notle159 - 返信
Any advice on a good way to clean the fan blades? Thanks for all the other tips!
Nicholas Pratt III - 返信
Thanks for the instructions, they helped me a lot!!! If there's one thing Sony didn't save on this console, it was screws 😂😂😂
Ferrera_Gabs - 返信
コメントを追加
統計データを表示:
過去 24時間: 107
過去 7 日: 717
過去 30 日: 3,327
今までの合計 54,445
