メインコンテンツにスキップ
PlayStation 4 Slim Hard Drive Replacement
必要な工具と部品
  1. PlayStation 4 Slim Hard Drive Replacement, Hard Drive: 手順 1、 2の画像 1 PlayStation 4 Slim Hard Drive Replacement, Hard Drive: 手順 1、 2の画像 2
    • Slide your thumb to the right to remove the plastic cover.
  2. PlayStation 4 Slim Hard Drive Replacement: 手順 2、 2の画像 1 PlayStation 4 Slim Hard Drive Replacement: 手順 2、 2の画像 2
    • Remove the silver 6 mm #0 Phillips screw that holds the hard drive caddy in place using your screwdriver.
    • This screw is very important as it ensures the drive does not come loose from the connector during operation.
  3. PlayStation 4 Slim Hard Drive Replacement: 手順 3、 3の画像 1 PlayStation 4 Slim Hard Drive Replacement: 手順 3、 3の画像 2 PlayStation 4 Slim Hard Drive Replacement: 手順 3、 3の画像 3
    • Pull out the black glossy tape handle using your fingers.
    • Remove the caddy from the bay.
  4. PlayStation 4 Slim Hard Drive Replacement: 手順 4、 3の画像 1 PlayStation 4 Slim Hard Drive Replacement: 手順 4、 3の画像 2 PlayStation 4 Slim Hard Drive Replacement: 手順 4、 3の画像 3
    • Remove all four 8 mm Phillips #0 screws from the hard drive caddy (two on each side).
  5. PlayStation 4 Slim Hard Drive Replacement: 手順 5、 2の画像 1 PlayStation 4 Slim Hard Drive Replacement: 手順 5、 2の画像 2
    • Slide your hand under the sled opening near the black tape handle, and press one of your fingers against the slate drive to push it up.
    • Carefully extract the hard drive from the caddy.
  6. PlayStation 4 Slim Hard Drive Replacement: 手順 6、 2の画像 1 PlayStation 4 Slim Hard Drive Replacement: 手順 6、 2の画像 2
    • Place your replacement hard drive or solid-state drive into the caddy.
    • Make sure the drive is upside with the connector's golden pins facing up like so.
    • Also be sure the connector is facing away from the black tape handle. This and the above point will ensure proper connection to the Playstation 4.
    • If installing a solid-state drive, make sure the screw holes of the sled and the drive are aligned properly before screwing back in.
    • This isn't a problem with 2.5" hard disk drives since the thickness allows for proper alignment during placement.
終わりに
To reassemble your device, follow these instructions in reverse order starting from Step 4.
Be sure to have a USB stick ready with an official PS4 firmware update file from Sony's website to reinstall the system software on your new hard disk or solid state drive. Follow Sony's instructions for formatting the USB as well.
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jordan Crooks
メンバー登録日: 02/02/24
205 ポイント
1ガイドが承認済み
チーム
UC Davis, Team 3-7, Andersen Winter 2024 UC Davis, Team 3-7, Andersen Winter 2024人のメンバー
UCD-ANDERSEN-W24S3G7
2 メンバー
3のガイドは作成済み
コメント 1 件
I need help why is my ps4 slim not turning on, all it does Is show the Play Station logo then the screen is black then turns off?
Henry Ramsey - 返信
コメントを追加
統計データ:
過去 24時間: 22
過去 7 日: 124
過去 30 日: 743
今までの合計 1,207
