はじめに
この修理ガイドを使って、PlayStation4 Slimの電源ユニットを取り出したり、交換します。
必要な工具と部品
TR8いじり止めトルクスドライバーを使って、見えるようになった長さ5.0mmのネジを反時計回りに回して外します。
T8 fits like a glove for me
Is there anything else you can use
randomweeb - 返信
A small flathead screwdriver will work
There is a small metal rod in the middle of the screw that isn’t allowing my t8 inside. Any insight on this?
Some T8 bits have a hole in the middle that will allow that rod to go through; some do not. If you have a set of multiple bits, check if there are any others labeled T8 or TR8 with that hole in the middle.
Nicholas -
There is a metal thing inside of the screw slot any insite on this?
たった今外したネジの側面が自分を向くようにして、Playstation 4 Slimを裏返しにして置きます。
手前側の2つの角を指で持ち上げます。
底部カバーを裏面角に向けてスライドさせて、持ち上げて外します。
It says to place it upside down, but didn't you do so in the previous step? I've been trying to unscrew the screw with my screwdriver that I got from here and if I had to had the system right side up, I'm afraid I might've stripped the screw from all the force I tried to use to get the screw out that will NOT budge. It didn't even move the slightest after removing the warranty sticker.
There is a single clip on the left side about 5cms in, and another clip on the right side equidistant to the one on the other side. Jamming a spudger in there first, and lifting those clips helped, and then I had to slide down to lift a total of 4 clips on each side (each about 4cms apart). Then push the cover away from you, if that makes more sense than “sliding it towards the back corners”, since the back corners are technically facing you.
I saw many video and tried it my self, you have to remove the hard disc before removing any cover.
Playstation 4 SlimのPSロゴを上向きにして、"SONY"と"PS4"を手前に向けます。
ここに翻訳を挿入する
ここに翻訳を挿入する
T8ドライバーを使って、2つのネジ(左に31.0mmネジ1本、右に24.0mmネジ1本あります)を反時計回りに回して外します。
#1プラスドライバーを使って、3.0mmネジを反時計回りに回して外します。
UK model seems to be different here. There's no Philips screw where there is on your image.
This regards EU models in general, i think. My danish version is the same.
電源ユニットを所定の位置に固定している16mmプラスネジを4本外します。
Only 2 Phillips actress here on my UK
Only 2 phillips screws on the US one as well.
I also only have two screws here in the US.
メタルシートを両手で掴んで、電源ユニット上部から持ち上げて外します。
I think the metal sheet protects the rest of the console or something from heating too much.
金属板の下に指をかけ、ケーブルを押さえながら電源ユニットの上部よりアンテナを取り外します。
What does this mean for part do? This part is not present in my console nor is the space where it's supposed to reside as shown in the picture above.
Me neither, guess they are different models.
電源ケーブルを指かピンセットでしっかりとつかみ、引き抜いて外します。
手で上に持ち上げ、電源ユニットを完全に取り外します。
Your guide is good but detail. Could be alot better for a start you forgot to mention the screw on the other side that must also be removed to let the power supply out of ps4 slim
Could you replace a ps4 slim model CUH-211B with a N16-160P1A power supply
Just because I feel like this needs to be stated clearly, “Do no attempt to pull the plug out by the wires!”
Pull from the plastic, male end of the plug or you’re going to end up have a very bad day.
Literally no way I can do it by the plastic, the only way is wires. Gotta risk it I guess
Misha FV -
You are right, pulling the wires is entirely wrong. I used the small rectangular, thin blue plastic to push the cable back from the socket. It was too tight. From my experience of repairing, never pull wires. The consequences of damaging it are not worth it.
デバイスを再組み立てする際は、これらの手順を逆の順番に従って作業を進めてください。
70 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
6 件のコメント
My PS4 not turning on
This was awesome. Thanks for the assist
I need help figuring out what I did to my ps4 and what needs replacement I had the new nba 2k 22 in the disc drive and the game was partly finished downloading so as it was doing that I brought shinobi striker which I previously had to use someone’s account to play it so the game popped up as light so I deleted it the first time and redownloaded it and it still said lite so then I deleted again but this time I double tapped the PlayStation button and it went to Home Screen slowed down then froze so I unplugged it plugged it back up and it wouldn’t turn on
My PS4 runs for 10 minutes and turns off again and again
I really appreciate this help hopefully this doesn't damage my PS4
Remove the screw directly to the left of that one in the picture as well. Should be silver.
Elizabeth Johnson - 返信
ihr seid so ein scheiß haufen das stimmt über haubt nix
Toaster 95 - 返信
einfach alles stimmt nicht
Toaster 95 - 返信
