はじめに
This guide starts with the process of opening up the Playstation 3 Super Slim and moves on to remove the optical drive in its entirety. If your PlayStation 3 Super Slim is not reading disks properly or you know that the problem with your device is due to a faulty optical drive, consider following these steps to replace it. Before following the steps to replace the optical drive, be sure that you have all the correct tools necessary, enough time to do the job carefully, and an uncluttered and clean workspace. When following the steps, make sure that you read them carefully and do not put too much pressure on the various parts of your device so that they do not break. Good luck with the replacement process and take your time!
必要な工具と部品
Remove the side HDD bay cover by sliding the panel towards the back of the device.
Remove the front white flex-ribbon cable by pulling upward from its base.
Remove the black and blue flex-ribbon cable behind it by pulling upward on the black tab, then pulling out the cable.
Install the replacement optical drive. To reassemble your device, follow these instructions in reverse order.
12 の人々がこのガイドを完成させました。
5 件のコメント
Hi i have a Question
I change the Optical Drive on my PS 3 Super Slim Named KEM850 PHA KES850 .But the new drive only play DVD not Blueray Game or Movie
An update was made without drive on board connected .can be this the problem. how can i fix them
Please Help
s
I am replacing the optical drive in my console. But didn't note where the drive ribbon was positioned!? Every video I have found, they just pop right in...my original and replacement drives, have larger receptacles than the ribbon it self. There are at least 5 pins, that don't have (potentially) anything connecting them, to the ribbon. I don't want to randomly place the ribbon in one of the possible (7?) positions and fry something in the process...so where do I connect the smaller ribbon?!
