メインコンテンツにスキップ
PlayStation 3 Super Slim Fan Replacement
必要な工具と部品
  1. PlayStation 3 Super Slim Fan Replacement, Power Supply Unit: 手順 1、 2の画像 1 PlayStation 3 Super Slim Fan Replacement, Power Supply Unit: 手順 1、 2の画像 2
    • Remove the side HDD bay cover by sliding the panel towards the back of the device.
    • The bay cover is found on the right side of the device.
  2. PlayStation 3 Super Slim Fan Replacement: 手順 2、 2の画像 1 PlayStation 3 Super Slim Fan Replacement: 手順 2、 2の画像 2
    • Remove all three black 9.8mm long screws with a T-8 security screwdriver.
    • Remove the blue 7.9mm long screw with a Phillips #1 screwdriver.
  3. PlayStation 3 Super Slim Fan Replacement: 手順 3、 2の画像 1 PlayStation 3 Super Slim Fan Replacement: 手順 3、 2の画像 2
    • Pull on the tab to remove the HDD.
    • The HDD should be removed and stored carefully to prevent damage to data.
  4. PlayStation 3 Super Slim Fan Replacement: 手順 4、 2の画像 1 PlayStation 3 Super Slim Fan Replacement: 手順 4、 2の画像 2
    • On the bottom of the device, pry out the three rubber feet covers with the metal spudger.
    • Remove the four black 36.3mm long screws underneath with a Phillips #1 screwdriver.
    • One screw is located underneath the warranty sticker. This sticker can either be peeled off or punctured through with a screwdriver.
  5. PlayStation 3 Super Slim Fan Replacement: 手順 5、 2の画像 1 PlayStation 3 Super Slim Fan Replacement: 手順 5、 2の画像 2
    • On the top of the device, unlatch the hook on the furthest right beneath the front panel, lift the panel slightly and apply pressure.
    • Unlatch the second right-side hook by sliding a plastic opening tool in the marked area.
    • Slide the panel to the left to unlatch the rest of the hooks.
    • This is probably the most difficult part of the procedure. If you cannot unlatch the hook on the front panel, you can attempt to pry all the hooks off. However, do this at your own risk, as these hooks break easily.
  6. PlayStation 3 Super Slim Fan Replacement: 手順 6、 1の画像 1
    • Remove the back panel by pressing down the tab on the right side of the device, and sliding the panel to the left.
  7. PlayStation 3 Super Slim Fan Replacement: 手順 7、 3の画像 1 PlayStation 3 Super Slim Fan Replacement: 手順 7、 3の画像 2 PlayStation 3 Super Slim Fan Replacement: 手順 7、 3の画像 3
    • Remove the five silver 20.8mm long screws with a Phillips #1 screwdriver.
    • Remove the two black 9.9mm long screws in the disc reader with a T-8 security screwdriver.
    • Remove the top black plastic shell.
  8. PlayStation 3 Super Slim Fan Replacement: 手順 8、 3の画像 1 PlayStation 3 Super Slim Fan Replacement: 手順 8、 3の画像 2 PlayStation 3 Super Slim Fan Replacement: 手順 8、 3の画像 3
    • Move the optical drive to the side to reveal one of the silver 8.8mm long screws.
    • Remove the two silver 8.8mm long screws on either side with a Phillips #1 screwdriver.
  9. PlayStation 3 Super Slim Fan Replacement: 手順 9、 3の画像 1 PlayStation 3 Super Slim Fan Replacement: 手順 9、 3の画像 2 PlayStation 3 Super Slim Fan Replacement: 手順 9、 3の画像 3
    • Remove the cable from the plug and remove the wires from the two plastic hooks.
    • When removing the cable from the plug, pull on the plastic male connecter, not on the wires.
    • Remove the power supply unit.
  10. PlayStation 3 Super Slim Fan Replacement, Optical Drive: 手順 10、 3の画像 1 PlayStation 3 Super Slim Fan Replacement, Optical Drive: 手順 10、 3の画像 2 PlayStation 3 Super Slim Fan Replacement, Optical Drive: 手順 10、 3の画像 3
    • Remove the front white flex-ribbon cable by pulling upward from its base.
    • Remove the black and blue flex-ribbon cable behind it by pulling upward on the black tab, then pulling out the cable.
  11. PlayStation 3 Super Slim Fan Replacement: 手順 11、 3の画像 1 PlayStation 3 Super Slim Fan Replacement: 手順 11、 3の画像 2 PlayStation 3 Super Slim Fan Replacement: 手順 11、 3の画像 3
    • Rotate the device 180 degrees.
    • Remove the back white flex-ribbon cable by pulling upward from its base.
    • Remove the optical drive.
  12. PlayStation 3 Super Slim Fan Replacement, Wi-Fi Antennas: 手順 12、 3の画像 1 PlayStation 3 Super Slim Fan Replacement, Wi-Fi Antennas: 手順 12、 3の画像 2 PlayStation 3 Super Slim Fan Replacement, Wi-Fi Antennas: 手順 12、 3の画像 3
    • Locate the white flex ribbon cable that connects the power button to the motherboard. Pull this cable out from the motherboard end.
    • Remove the five black 8.3mm long screws with a Phillips #1 screwdriver.
    • Remove the two silver 12.8mm long screws with a Phillips #1 screwdriver.
    • Remove the device from the bottom shell casing.
  13. PlayStation 3 Super Slim Fan Replacement: 手順 13、 3の画像 1 PlayStation 3 Super Slim Fan Replacement: 手順 13、 3の画像 2 PlayStation 3 Super Slim Fan Replacement: 手順 13、 3の画像 3
    • Remove the two black 8.3mm long screws with a Phillips #1 screwdriver from the Wi-Fi antennas.
    • Lift the Wi-Fi antennas off their mount.
  14. PlayStation 3 Super Slim Fan Replacement: 手順 14、 3の画像 1 PlayStation 3 Super Slim Fan Replacement: 手順 14、 3の画像 2 PlayStation 3 Super Slim Fan Replacement: 手順 14、 3の画像 3
    • Use a plastic opening tool to remove the Wi-Fi wires from their sockets on the motherboard.
    • Remove the wires from the hooks around the motherboard and fan cover to completely remove the antennas.
    • The Wi-Fi antennas' ports are labeled B and W on the motherboard for reassembly.
    • To insert your new Wi-Fi antennas, insert the wires of your replacement Wi-Fi antennas into each socket, feed the wires through the hooks, and install the antennas on their mount.
  15. PlayStation 3 Super Slim Fan Replacement, Fan: 手順 15、 3の画像 1 PlayStation 3 Super Slim Fan Replacement, Fan: 手順 15、 3の画像 2 PlayStation 3 Super Slim Fan Replacement, Fan: 手順 15、 3の画像 3
    • Remove the two black 14.5mm long screws with a Phillips #1 screwdriver from the center of the bottom metal casing.
    • Remove the four silver 8.7mm long screws with a Phillips #1 screwdriver around the edges of the bottom metal casing.
    • Remove the bottom metal casing.
  16. PlayStation 3 Super Slim Fan Replacement: 手順 16、 3の画像 1 PlayStation 3 Super Slim Fan Replacement: 手順 16、 3の画像 2 PlayStation 3 Super Slim Fan Replacement: 手順 16、 3の画像 3
    • Remove the fan wire from its plug on the top metal casing.
    • When removing the wire, do not pull from the wire. Instead, pull from the white plastic male connecter.
    • Remove the motherboard from the top metal casing. Lift from the side with the two USB plugs to avoid damaging the four back ports.
    • There is a thermal compound between the top metal casing and the motherboard in the center, so you may have to apply more force than usual. Do not force the two pieces apart, but slowly apply more and more pressure until the adhesive gives.
    • During reassembly, remember to replace the old thermal compound, as it cannot be reused.
  17. PlayStation 3 Super Slim Fan Replacement: 手順 17、 3の画像 1 PlayStation 3 Super Slim Fan Replacement: 手順 17、 3の画像 2 PlayStation 3 Super Slim Fan Replacement: 手順 17、 3の画像 3
    • On the bottom of the top metal casing, remove the three black 8.0mm long screws with a Phillips #1 screwdriver.
    • Remove the fan from the plastic cover.
終わりに
Install the replacement fan. To reassemble your device, follow these instructions in reverse order.
42 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Joseph O'Connor
メンバー登録日: 04/14/16
2,383 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 34-13, Maness Spring 2016 Cal Poly, Team 34-13, Maness Spring 2016人のメンバー
CPSU-MANESS-S16S34G13
4 メンバー
21のガイドは作成済み
コメント 1 件
Thanks for this fan tutorial I have not been able to find any on YouTube about taking apart the fan for cleaning the heat sync's and fan blades it self. So thank you so very much.
Steven Littchum - 返信
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 103
過去 30 日: 473
今までの合計 30,735
