メインコンテンツにスキップ
PlayStation 3 Slimの電源の交換
必要な工具と部品
  1. PlayStation 3 Slimの電源の交換, トップカバー: 手順 1、 1の画像 1
    • PS3を裏返し、裏面を下にして置きます。
    • 下部ケースから封印シールをゆっくりと剥がすと、隠れたネジカバーが表れます。
    • VOIDという文字が転写されないようにするためには、シールをゆっくりと温めて、きれいに剥がして交換します。
    Don’t even need to bother with the sticker anymore since SONY does not care what you do with them anymore.
    Travis Wheeler - 返信
  2. PlayStation 3 Slimの電源の交換: 手順 2、 2の画像 1 PlayStation 3 Slimの電源の交換: 手順 2、 2の画像 2
    • 金属製スパッジャーの平面側先端を使い、下部ケース端周辺の7つのネジカバーをこじ開けます。
  3. PlayStation 3 Slimの電源の交換: 手順 3、 1の画像 1
    • トップカバーを下部ケースに固定している37mmプラスネジを7本外します。
  4. PlayStation 3 Slimの電源の交換: 手順 4、 1の画像 1
    • Blu-rayドライブの開口部下側の13.3mmT8セキュリティトルクスネジを4本外します(ネジが3本しかないモデルもあります)。
    Its 4 screws beneath the blu-ray
    Manuel - 返信
    Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening.
    Daniel Tlapa - 返信
    Can we edit this to say 4 screws?
    revanantwraith - 返信
    I made the change from three to four screws, but you're able to edit the guides as well. If you want to edit something, you can click the Edit link on the right side of any guide step, or the Edit link at the top right of the page (sandwiched in-between View and History).
    Taylor Arnicar -
    Do you guys have a guide for the PS3 Slim Model 3001A. The fan is different than this model.
    emknight04 - 返信
    3001a is basically same motherboard but cheaper plastic bd drive other than that its exactly the same until you get to the new slim line
    Robert -
    Anyone know an online retailer with a competitive price for the replacement fan?
    Jared - 返信
    My PS3 had only three Torx screws. Having four in the diagram was initially confusing. Obviously they made a mid-stream change at some point (mine is several years old now).
    corygbooker - 返信
    I've accidentally removed the ribbon cable from the blu-Ray drive and can not seem to figure out how to reconnect it. Can anyone help?
    OneIfByLand - 返信
    Take the top off the drive, connect the ribbon to the motherboard then replace the drive sliding the ribbon through the slot on the bottom of the drive and reconnect to the laser.
    KcXbox Repair -
    pls help i have to tear down my ps3 slim but the 4 srews are very hard to take it out because there is a needle in the middle pls hep
    vbrabandt - 返信
    If the screw has a pin in the center, that means it is a security Torx meant to prevent tampering. To remove this screw, follow the guide I have linked below...
    http://www.instructables.com/id/Removing...
    Telpack - 返信
    How do u buy the screw driver for these screws
    mistergalacta hoggy - 返信
    Online at the usual suspects?
    Or some hobby stores or places that sell tools will sometimes carry these.
    revanantwraith -
    Anyone else's screws for this step need the T7 bit instead of T8?
    Michael J Cotton - 返信
    What is the name of this screwdriver
    Mohammad Shawa - 返信
  5. PlayStation 3 Slimの電源の交換: 手順 5、 2の画像 1 PlayStation 3 Slimの電源の交換: 手順 5、 2の画像 2
    • 後端からトップカバーを持ち上げ、PS3前方に向かって回転させます。
    • PS3からトップカバーを持ち上げて外します。
    I just want to open the top cover to clean the fan. Do I need to unscrew the four security screws?
    Aryan - 返信
  6. PlayStation 3 Slimの電源の交換, 電源: 手順 6、 2の画像 1 PlayStation 3 Slimの電源の交換, 電源: 手順 6、 2の画像 2
    • ACインレットコネクタのロック機構をつまんで、まっすぐ持ち上げて電源から接続を外します。
  7. PlayStation 3 Slimの電源の交換: 手順 7、 1の画像 1
    • DC-Outケーブルをまっすぐ引き上げ、コネクタを持ち上げて、電源のソケットから外します。
    Those two screws are tight down there what do you recommend I use?
    Megan bronner - 返信
  8. PlayStation 3 Slimの電源の交換: 手順 8、 1の画像 1
    • 電源を下部ケースに固定している7.6mmプラスネジを2本外します。
    Question: if a screw doesn't come out, what do you recommend, without potentially damaging the system, inside and out?
    kramiz2488 - 返信
    It seems these can be quite tight, but they did come loose with someextra force in my case. They did that thing where it makes cracking sounds, but nothing really breaks. They're just really tight in there. - I just wouldn't recommend taking these out too often.
    Michael Hendriks - 返信
    The screwdrivers on the guide didn't work mine just don't come out any tips model is slim CECH 2001A
    Step 8
    Jose Arrieta - 返信
    These screws work as a ground pass through between the motherboard shields and the power supply. My cousin took his PS3 to a repair shop to replace the power supply, they didn’t put the screws back in after that and the PS was shutting down suddenly (no light green or red), put a couple of new screws and it’s being working fine since
    Mauricio González - 返信
    Sometime ago i took apart my PS3 out of curiosity, When puting it back together, i messed it up, I stripped one of the PSU screws. Now, i can't take it apart for a paste replacement. Any ideas?
    Franco Iván Bello Rojas - 返信
    The screws don't come out how do I fix this without breaking anything
    Suck dick - 返信
    I had the same problem with very tight screws on PS3 power supply. I solved it by purchasing a Screw removal / extractor gripping pliers long nose style , with unique non-slip jaws for quickly extracting damaged / stuck screws. ENGINEER PZ-60 Neji-Saurus,Silver. ( bought mine on Amazon)
    These pliers have special grips on tapered end to hold and turn stripped or rusty screws. It took a lot of effort, but screws finally came out using these pliers. A bit of sewing machine oil and prising under the washers with a flat screwdrvers helps too. Failing that, take it to repair shop as they are VERY TIGHT screws on some models of PS3.
    hubert hanks - 返信
    I need some advice I have taken apart my PS3 slim unit to clean it. I bought it second hand last year and it is filthy, I am having issues because the screws holding down the power supply are very tight, they are not stripped and I am using the right screwdriver. I don’t want to damage the screws, can anyone help?
    Sam - 返信
  9. PlayStation 3 Slimの電源の交換: 手順 9、 1の画像 1
    • 電源をPS3前部から見える左端から上方に持ち上げます。
  10. PlayStation 3 Slimの電源の交換: 手順 10、 2の画像 1 PlayStation 3 Slimの電源の交換: 手順 10、 2の画像 2
    • 2番目の画像で示されている2つの金属製のポストから外れるまで、電源の左端を持ち上げ続けます。
    • ケーブルが巻き込まれないよう注意しながら、PS3から電源を取り外します。
    It seems it kind of ends for me here. I can only lift the left side about an inch and then the right side stays down like it’s stuck to something underneath. It feels like I’m bending something. Could something have melted underneath?… It's really stuck, I can't get it to come loose. And I can't see much shining a light into it either. - Any tips?…
    Did you undo the screws?
    Phoenix Jameson -
    I had the same issue but was able to get it off. The right side (as per the above picture) has two long column like sections that actually goes into the machine. Took me a bit of wiggling and some brute force.
    Ivan Amaro - 返信
    You just lift the whole power supply up. There’s no need to start from the left? Is it possible to bend the two metal posts if lifting from the left?
    Ken - 返信
    Needs medium flat screw driver as wedge to help to lift the power supply in the right side or exert more force in your right arm provided the front of PS3 is at your front.
    Dasol - 返信
    Um, I translated the guide from French to English and the name of the guide was “Food” and the description said “This guide shows you how to replace your diet” The translation is incorrect just to let you know!
    Liam Kandell - 返信
    Hi! Thanks for you attention! But no worries, the French word “alimentation” means power, food or diet depending the context.
    Claire Miesch -
    Alright, thanks!
    Liam Kandell - 返信
終わりに
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
61 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
5人の作成者と共同で作成されました。
Andrew Bookholt
586,715 ポイント
619のガイドは作成済み
11 件のコメント
Hello, my question is I have an american ps3 which works on 110 volts and I'm in europe where they use 220volts so if I plug my ps3 without any converters will it burn or will it wor? Because I have a laptop and it works fine will my ps3 work like that aswell?
Remigijus Untulis - 返信
Perhaps, you should check the model of your PS3 and verify online. I have the CECH-2501B model (110v) but I use it in Nigeria (220v).
N3RVE -
Need help with console or trouble shooting the problem I am in the repair and purchased used or damage consoles even get it In way I can be able to talk to people who is looking for trouble shooting on phone or email or u to choose. But any console or device I am interested in buying it so I have it on hand I have seen people pay way more 4 the part. Wene it is sometimes. New or used Console r cheaper to get the whole different devices then part for the console
Jason Ellis -
More to my comment I can be able to talk or text or email. SO you can do it yourself and it's not to bad to diy and your up to run the console after u fixed it. Do I you self. (Diy) even if people walk through it step 4 step.
Jason Ellis -
I have a PS3 Slim (CECH-3004B)
Can I install any PSU what is made for PS3 slim?
Or I should make a research what kind of PSU can be installed into my model (CECH-3004B) ?
Thank you for your help in advance ^^
Jani - 返信
My ps3 2501A was dropped while moving now it wont show up o the screen or turn off .. What can it be ?
Wendy Hernandez - 返信
Hello i was moving and my ps3 slim 2501A was dropped now it wont show up on the screen nor will it connect on hdmi or usb or anythig and it wont turn off alone what can it be?
i have a ps3 i bought it from the uk and i am in the usa the ps3 is 220 ait wont stay one what should i do, should i buy a 110-220 power supply
kenny jean - 返信
My PS3 cech 2001a has quit powering on after I opened it to retrieve a stuck game disk what should I do now
jaiden Knight - 返信
When I press the power button, the device turns on and turns off and the 5V disappears on my ps3 slim
aymn bek - 返信
Not sure if this is where I should post this, I have a ps3 it turns on and the light goes green for 10 seconds and then it just shuts down. Not sure whats wrong with it any help would be great.
Joao Barroqueiro - 返信
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 120
過去 30 日: 525
今までの合計 92,079
