はじめに
Use this guide to replace your power supply.
必要な工具と部品
Turn the PS3 over and lay it on its backside.
Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
61 の人々がこのガイドを完成させました。
11 件のコメント
Hello, my question is I have an american ps3 which works on 110 volts and I'm in europe where they use 220volts so if I plug my ps3 without any converters will it burn or will it wor? Because I have a laptop and it works fine will my ps3 work like that aswell?
Perhaps, you should check the model of your PS3 and verify online. I have the CECH-2501B model (110v) but I use it in Nigeria (220v).
N3RVE -
Need help with console or trouble shooting the problem I am in the repair and purchased used or damage consoles even get it In way I can be able to talk to people who is looking for trouble shooting on phone or email or u to choose. But any console or device I am interested in buying it so I have it on hand I have seen people pay way more 4 the part. Wene it is sometimes. New or used Console r cheaper to get the whole different devices then part for the console
More to my comment I can be able to talk or text or email. SO you can do it yourself and it's not to bad to diy and your up to run the console after u fixed it. Do I you self. (Diy) even if people walk through it step 4 step.
