メインコンテンツにスキップ
PlayStation 3 Slim Control Board Replacement
必要な工具と部品
  1. PlayStation 3 Slim Control Board Replacement, Top Cover: 手順 1、 1の画像 1
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. PlayStation 3 Slim Control Board Replacement: 手順 2、 2の画像 1 PlayStation 3 Slim Control Board Replacement: 手順 2、 2の画像 2
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. PlayStation 3 Slim Control Board Replacement: 手順 3、 1の画像 1
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. PlayStation 3 Slim Control Board Replacement: 手順 4、 1の画像 1
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. PlayStation 3 Slim Control Board Replacement: 手順 5、 2の画像 1 PlayStation 3 Slim Control Board Replacement: 手順 5、 2の画像 2
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
  6. PlayStation 3 Slim Control Board Replacement, Control Board: 手順 6、 2の画像 1 PlayStation 3 Slim Control Board Replacement, Control Board: 手順 6、 2の画像 2
    • Use the tip of a spudger to pry the control board out of its housing within the lower case.
    • Pull the control board ribbon cable away from its socket on the control board.
終わりに
21 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Andrew Bookholt
586,022 ポイント
619のガイドは作成済み
2 件のコメント
I have a PS3 slim that won't turn on, unfortunately my Power/eject button and ribbon cable are completely removed from my PS3. Can I turn it on without the button/ribbon cable?
wrestlemaniafreak - 返信
I replaced the entire psu but without a standby light I have no idea if I'm close to powering it on. I suppose I could get a multimeter but I don't know what I'm testing. Any info would be appreciated.
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 29
過去 30 日: 136
今までの合計 26,801
