メインコンテンツにスキップ
PlayStation 3 Slim AC Inlet Replacement
必要な工具と部品
  1. PlayStation 3 Slim AC Inlet Replacement, Top Cover: 手順 1、 1の画像 1
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. PlayStation 3 Slim AC Inlet Replacement: 手順 2、 2の画像 1 PlayStation 3 Slim AC Inlet Replacement: 手順 2、 2の画像 2
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. PlayStation 3 Slim AC Inlet Replacement: 手順 3、 1の画像 1
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. PlayStation 3 Slim AC Inlet Replacement: 手順 4、 1の画像 1
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. PlayStation 3 Slim AC Inlet Replacement: 手順 5、 2の画像 1 PlayStation 3 Slim AC Inlet Replacement: 手順 5、 2の画像 2
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
  6. PlayStation 3 Slim AC Inlet Replacement, Power Supply: 手順 6、 2の画像 1 PlayStation 3 Slim AC Inlet Replacement, Power Supply: 手順 6、 2の画像 2
    • Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
  7. PlayStation 3 Slim AC Inlet Replacement: 手順 7、 1の画像 1
    • Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
  8. PlayStation 3 Slim AC Inlet Replacement: 手順 8、 1の画像 1
    • Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
  9. PlayStation 3 Slim AC Inlet Replacement: 手順 9、 1の画像 1
    • Lift the power supply upward from its left edge as viewed from the front of the PS3.
  10. PlayStation 3 Slim AC Inlet Replacement: 手順 10、 2の画像 1 PlayStation 3 Slim AC Inlet Replacement: 手順 10、 2の画像 2
    • Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture.
    • Remove the power supply from the PS3, minding any cables that may get caught.
  11. PlayStation 3 Slim AC Inlet Replacement, AC Inlet: 手順 11、 2の画像 1 PlayStation 3 Slim AC Inlet Replacement, AC Inlet: 手順 11、 2の画像 2
    • Lift the AC inlet cables straight upward to remove the AC inlet from the lower case.
終わりに
25 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Andrew Bookholt
586,263 ポイント
619のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 109
今までの合計 25,169
