はじめに
If you want to replace the fan or clean the fan system - video tutorial:
Please SUBSCRIBE to my channel ツ
ビデオの概要
Disconnect the fan cable and remove the nine screws from the bottom side. Disconnect the fan cable and remove the nine screws from the bottom side. Disconnect the fan cable and remove the nine screws from the bottom side.
  • Disconnect the fan cable and remove the nine screws from the bottom side.
コメントを追加する
Remove the two heat sink clamps and bottom shield, then gently separate  the motherboard off the top shield. Remove the two heat sink clamps and bottom shield, then gently separate  the motherboard off the top shield. Remove the two heat sink clamps and bottom shield, then gently separate  the motherboard off the top shield.
  • Remove the two heat sink clamps and bottom shield, then gently separate the motherboard off the top shield.
コメントを追加する
Remove the four Phillips screws and lift the top shield. Remove the four Phillips screws and lift the top shield. Remove the four Phillips screws and lift the top shield.
  • Remove the four Phillips screws and lift the top shield.
コメントを追加する
コメントを追加する
まとめ
5 の人々がこのガイドを完成させました。
ZFix
メンバー登録日: 2013年12月09日
153,285 ポイント
430のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
277 メンバー
724のガイドは作成済み
Awesome guide. Thank you so much. I did it, but now I just wonder what that white stuff was when I removed the motherboard. I think it's that thermal stuff people have been talking about and I suppose I have to replace that. I also hope that it's the fan that is what's causing my PS3 to say that it's overheating and shut off. I'm so glad you guys posted this. Great job. I rather do it myself than pay Sony an arm and a leg. Cheers!
chetacheez - 返信
This is CPU / GPU thermal paste / compound. I recommend you Arctic MX-2, MX-4. It is very good and not expensive.
ZFix -
コメントを追加する
統計データを表示:
過去 24時間: 4
過去 7 日: 17
過去 30 日: 92
今までの合計 7,179
