はじめに
このガイドを参照して、PS3のBlu-rayディスクドライブを交換しましょう。このドライブは、ソニーが特許を持っています。
必要な工具と部品
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
179 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
22 件のコメント
great work guys and ladies.......haha went without a snag!
I have a question I have followed your guide properly and removed my drive and found that the laser and disc loader are both need replaced. My question is when I go online and look for the replacement it sometimes shows just the laser then others shows the driver. I want the entire component as seen in this guide above. Do these come intact with everything in it when I buy it online. Can you please help.
Thank you,
Thomas Martinez
Tomlvgmartinez@yahoo.com
Ive been able to remove the drive and I think it's fixed. To get it back together how do you get that ribbon underneath to go back into the slot? Is there a trick? I can get it lined up, but it won't go in.
Thanks for the help
Ken,
Don' t know if this helps you now after all this time, but maybe it will help others with the same issue.
a) On the slot where the ribbon is to be inserted, is a lock clip. You pull up on that (gently).
b) Slide the ribbon in now with the clip lifted.
c) While securing the ribbon down in the slot, push the clip down, it will lock the ribbon in the slot.
Hopefully this helps, I didn't realize the clip could be lifted. While it's down, it is impossible to set the ribbon in.
ShuriKen
ShuriKen -
