メインコンテンツにスキップ
PlayStation 3 Lower Case Replacement
必要な工具と部品
  1. PlayStation 3 Lower Case Replacement, Smart Plate: 手順 1、 2の画像 1 PlayStation 3 Lower Case Replacement, Smart Plate: 手順 1、 2の画像 2
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Lower Case Replacement: 手順 2、 1の画像 1
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Lower Case Replacement: 手順 3、 3の画像 1 PlayStation 3 Lower Case Replacement: 手順 3、 3の画像 2 PlayStation 3 Lower Case Replacement: 手順 3、 3の画像 3
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Lower Case Replacement: 手順 4、 1の画像 1
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Lower Case Replacement, Top Cover: 手順 5、 1の画像 1
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Lower Case Replacement: 手順 6、 1の画像 1
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Lower Case Replacement, Blu-ray Disc Drive: 手順 7、 1の画像 1
    • Disconnect the Blu-ray power cable from the motherboard.
    • Pull the connector straight up and out of its socket.
  8. PlayStation 3 Lower Case Replacement: 手順 8、 1の画像 1
    • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
  9. PlayStation 3 Lower Case Replacement: 手順 9、 3の画像 1 PlayStation 3 Lower Case Replacement: 手順 9、 3の画像 2 PlayStation 3 Lower Case Replacement: 手順 9、 3の画像 3
    • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the Blu-ray drive from the PS3.
    • If replacing the Blu-ray drive, transfer the power cable to your new drive.
  10. PlayStation 3 Lower Case Replacement, Motherboard Assembly: 手順 10、 1の画像 1
    • Pull the control board ribbon cable straight up and out of its socket on the motherboard.
  11. PlayStation 3 Lower Case Replacement: 手順 11、 2の画像 1 PlayStation 3 Lower Case Replacement: 手順 11、 2の画像 2
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
    • Remove the control board and its attached cable from the PS3.
  12. PlayStation 3 Lower Case Replacement: 手順 12、 1の画像 1
    • Remove the following eight screws securing the motherboard assembly to the lower case:
    • Seven 12 mm Phillips screws (ph2)
  13. PlayStation 3 Lower Case Replacement: 手順 13、 1の画像 1
    • Remove the control board bracket.
  14. PlayStation 3 Lower Case Replacement: 手順 14、 2の画像 1 PlayStation 3 Lower Case Replacement: 手順 14、 2の画像 2
    • Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
    • Remove the hard drive bay cover.
  15. PlayStation 3 Lower Case Replacement: 手順 15、 1の画像 1
    • Lift the motherboard assembly out of the lower case.
  16. PlayStation 3 Lower Case Replacement, Lower Case: 手順 16、 1の画像 1
    • Lower case remains.
終わりに
12 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Walter Galan
694,695 ポイント
1,203のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 54
今までの合計 17,951
