はじめに
Use this guide to replace a broken control board.
Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
Remove the following seven screws:
Six 52 mm Phillips screws
One 30 mm Phillips screw
Lift the top cover from its rear edge and rotate it toward the front of the PS3.
Remove the top cover.
There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit front the rear of the machine with a spudger to release the rear right of the casing.
Use your fingernail to flip up the retaining flap on the control board ribbon cable socket.
Pull the control board ribbon cable out of its socket.
14 の人々がこのガイドを完成させました。
2 件のコメント
Could anyone tell me if they would have the connection pin of this board, as I would like to fit it into a motherboard.
