メインコンテンツにスキップ
PlayStation 2 Slimline SPU-3170 Laser Replacement
必要な工具と部品
  1. PlayStation 2 Slimline SPU-3170 Laser Replacement, Outer Shell: 手順 1、 1の画像 1
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline SPU-3170 Laser Replacement: 手順 2、 3の画像 1 PlayStation 2 Slimline SPU-3170 Laser Replacement: 手順 2、 3の画像 2 PlayStation 2 Slimline SPU-3170 Laser Replacement: 手順 2、 3の画像 3
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline SPU-3170 Laser Replacement: 手順 3、 3の画像 1 PlayStation 2 Slimline SPU-3170 Laser Replacement: 手順 3、 3の画像 2 PlayStation 2 Slimline SPU-3170 Laser Replacement: 手順 3、 3の画像 3
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline SPU-3170 Laser Replacement: 手順 4、 3の画像 1 PlayStation 2 Slimline SPU-3170 Laser Replacement: 手順 4、 3の画像 2 PlayStation 2 Slimline SPU-3170 Laser Replacement: 手順 4、 3の画像 3
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline SPU-3170 Laser Replacement, Remove screws and white tab: 手順 5、 3の画像 1 PlayStation 2 Slimline SPU-3170 Laser Replacement, Remove screws and white tab: 手順 5、 3の画像 2 PlayStation 2 Slimline SPU-3170 Laser Replacement, Remove screws and white tab: 手順 5、 3の画像 3
    • Remove the 2 philips screws, marked in red.
    • Remove the white plastic slider holder.
    • Picture 3 shows how it should be done.
  6. PlayStation 2 Slimline SPU-3170 Laser Replacement, Remove slider: 手順 6、 1の画像 1
    • Remove the slider as shown in the picture. You could do this with your fingers, otherwise take tweezers to remove it.
  7. PlayStation 2 Slimline SPU-3170 Laser Replacement, Disconnect the laser: 手順 7、 3の画像 1 PlayStation 2 Slimline SPU-3170 Laser Replacement, Disconnect the laser: 手順 7、 3の画像 2 PlayStation 2 Slimline SPU-3170 Laser Replacement, Disconnect the laser: 手順 7、 3の画像 3
    • Do not remove the laser yet!
    • Take the laser out of the rail and rotate it.
    • Open up the connector by both sides with your fingernail or spudger. Be EXTREME carefull here, as it can break easily! (if the laser is broken, it won't matter, you can even practice on the broken laser).
    • Take the ribbon cable out, it should come out with ease.
  8. PlayStation 2 Slimline SPU-3170 Laser Replacement, Transfer slider: 手順 8、 2の画像 1 PlayStation 2 Slimline SPU-3170 Laser Replacement, Transfer slider: 手順 8、 2の画像 2
    • Remove the philips screw from the laser and take off the slider.
    • Transfer the slider to the new laser and screw it down.
  9. PlayStation 2 Slimline SPU-3170 Laser Replacement, Desolder anti-static security: 手順 9、 2の画像 1 PlayStation 2 Slimline SPU-3170 Laser Replacement, Desolder anti-static security: 手順 9、 2の画像 2
    • Most of the lasers have some solder on it for the anti-static security. You NEED to remove the solder, otherwise it won't work. Remove the solder with desolder wick.
    • You need a soldering station to DESOLDER the anti-static (if it's there), without de-soldering it, the laser could be busted!!
    • 2nd picture shows how it should be done. If you have the same result, your good to go. If you are not sure, just use your soldering iron again to remove some more (don't hold it too long on it, otherwise you could damage something).
  10. PlayStation 2 Slimline SPU-3170 Laser Replacement, Laser assembly: 手順 10、 1の画像 1
    • Remove the blue sticker from the laser (if it has one). Put the laser back in and all other removed components (follow guide in reverse order). When you've put everything back, it should look like the provided picture.
終わりに
To reassemble your device, follow these instructions in reverse order. Do not forget to transfer the slider from the old laser to the new one!
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
koppie007
メンバー登録日: 08/22/13
11,902 ポイント
9のガイドは作成済み
チーム
Protectors Of The Game Systems Protectors Of The Game Systems人のメンバー
Community
4 メンバー
24のガイドは作成済み
3 件のコメント
Hi there,
Do you need to worry about the laser cd/dvd parameters when installing the new one?
Thanks
Simon
Simon Jones - 返信
Hi Simon! No, for the PS2 slim, this is not the case. Regarding the "PS2 Phat", sometimes it is required to adjust the parameters, same for the PS1.
koppie007 -
Hi there. I need help! How can I replace the same central engine. In other models it is simple, but here it is rigidly attached to the frame. I will be grateful for your help. thank you
Alex - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 42
過去 30 日: 202
今までの合計 6,430
