はじめに
Use this guide to walk through a step-by-step process on how to properly replace a broken fan in the PlayStation 2 Slimline SCPH-7500x . The fan’s purpose is to keep the other components in the PlayStation from overheating. You should hear the fan run intermittently while the PlayStation is on. If you do not hear a fan or the system is overheating try following this guide to replace it.
必要な工具と部品
手順1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell
注意: 手順 1-7 は、作業進行中としてマークされている ガイド から引用されています。
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
4 の人々がこのガイドを完成させました。
