メインコンテンツにスキップ
はじめに
This is a step-by-step guide on the PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement, which keeps track of the time within the Playstation 2 when off.
The clock battery is a minor fix for the Playstation and will continue to work without it. It only job is to continue the use of the internal clock once the playstation is off, so when it turns on again, the time will remain accurate.
The process on replacing is a simple 2 step process that will require a Phillips screwdriver, tweezers, and a spudger and requires removing the Outer Shell before staring the guide. Make sure to power off the device and disconnect from any external power source before beginning.
パーツ
パーツは指定されていません。
    • Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
  1. Locate the six feet on the bottom of the PS2.
    • Locate the six feet on the bottom of the PS2.
    • Five of these feet are in plain sight while the last foot is located under the black void sticker on the back of the device.
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or the screw should be in plain sight.
  2. Remove the five visible feet from the bottom of the device using a spudger. Remove the five visible feet from the bottom of the device using a spudger. Remove the five visible feet from the bottom of the device using a spudger.
    • Remove the five visible feet from the bottom of the device using a spudger.
  3. Remove the sticker and then remove the 6th foot. Remove the sticker and then remove the 6th foot.
    • Remove the sticker and then remove the 6th foot.
  4. After all of the feet have been removed,  Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2. After all of the feet have been removed,  Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2. After all of the feet have been removed,  Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
    • After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
  5. Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides. You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins. You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
    • Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
    • You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
    It took force to open it, but i broke a plastic pin where the screws enter
    Vasco Mateus - 返信
    You can use a pick to get the thin edge up without breaking anything.
    Mira Mogzec - 返信
  6. If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
  7. Identify the clock battery, then use tweezers to disconnect the connector from the motherboard. Identify the clock battery, then use tweezers to disconnect the connector from the motherboard. Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
    • Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
  8. Gently lift the battery up from the battery compartment using a spudger. Gently lift the battery up from the battery compartment using a spudger.
    • Gently lift the battery up from the battery compartment using a spudger.
終わりに
3 の人々がこのガイドを完成させました。
Jared Hirata
メンバー登録日: 2013年04月09日
621 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 17-4, Regan Spring 2013 Cal Poly, Team 17-4, Regan Spring 2013人のメンバー
CPSU-REGAN-S13S17G4
3 メンバー
21のガイドは作成済み
コメント1件
These instructions take for granted how the battery itself should be replaced. I imagine you reconnect the contact with the red wire to the positive side of the CR2032 battery and the contact for the black wire to the negative and wrap electrical tape around the entire thing BEFORE reconnecting it and then following these instructions in reverse order.
Patrick Lewis - 返信
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 32
今までの合計 2,918
