メインコンテンツにスキップ
PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement
必要な工具と部品
  1. 注意: 手順 1-7 は、作業進行中としてマークされている ガイド から引用されています。
    • Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
  2. PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement: 手順 2、 1の画像 1
    • Locate the six feet on the bottom of the PS2.
    • Five of these feet are in plain sight while the last foot is located under the black void sticker on the back of the device.
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or the screw should be in plain sight.
  3. PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement: 手順 3、 3の画像 1 PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement: 手順 3、 3の画像 2 PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement: 手順 3、 3の画像 3
    • Remove the five visible feet from the bottom of the device using a spudger.
  4. PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement: 手順 4、 2の画像 1 PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement: 手順 4、 2の画像 2
    • Remove the sticker and then remove the 6th foot.
  5. PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement: 手順 5、 3の画像 1 PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement: 手順 5、 3の画像 2 PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement: 手順 5、 3の画像 3
    • After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
  6. PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement: 手順 6、 3の画像 1 PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement: 手順 6、 3の画像 2 PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement: 手順 6、 3の画像 3
    • Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
    • You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
  7. PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement: 手順 7、 1の画像 1
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
  8. PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement, Clock Battery: 手順 8、 3の画像 1 PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement, Clock Battery: 手順 8、 3の画像 2 PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement, Clock Battery: 手順 8、 3の画像 3
    この手順で使用する道具:
    購入する
    • Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
  9. PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement: 手順 9、 2の画像 1 PlayStation 2 Slimline SCPH-7500x Clock Battery Replacement: 手順 9、 2の画像 2
    • Gently lift the battery up from the battery compartment using a spudger.
終わりに
8 の人々がこのガイドを完成させました。
作成者
17人の作成者と共同で作成されました。
Jared Hirata
メンバー登録日: 04/09/13
880 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 17-4, Regan Spring 2013 Cal Poly, Team 17-4, Regan Spring 2013人のメンバー
CPSU-REGAN-S13S17G4
3 メンバー
28のガイドは作成済み
コメント 1 件
These instructions take for granted how the battery itself should be replaced. I imagine you reconnect the contact with the red wire to the positive side of the CR2032 battery and the contact for the black wire to the negative and wrap electrical tape around the entire thing BEFORE reconnecting it and then following these instructions in reverse order.
Patrick Lewis - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 21
過去 30 日: 95
今までの合計 5,172
