メインコンテンツにスキップ
PlayStation 2 Slimline PVR-802W Laser Replacement
必要な工具と部品
  1. PlayStation 2 Slimline PVR-802W Laser Replacement, Outer Shell: 手順 1、 1の画像 1
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline PVR-802W Laser Replacement: 手順 2、 3の画像 1 PlayStation 2 Slimline PVR-802W Laser Replacement: 手順 2、 3の画像 2 PlayStation 2 Slimline PVR-802W Laser Replacement: 手順 2、 3の画像 3
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline PVR-802W Laser Replacement: 手順 3、 3の画像 1 PlayStation 2 Slimline PVR-802W Laser Replacement: 手順 3、 3の画像 2 PlayStation 2 Slimline PVR-802W Laser Replacement: 手順 3、 3の画像 3
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline PVR-802W Laser Replacement: 手順 4、 3の画像 1 PlayStation 2 Slimline PVR-802W Laser Replacement: 手順 4、 3の画像 2 PlayStation 2 Slimline PVR-802W Laser Replacement: 手順 4、 3の画像 3
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline PVR-802W Laser Replacement, Remove screws and brackets: 手順 5、 3の画像 1 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove screws and brackets: 手順 5、 3の画像 2 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove screws and brackets: 手順 5、 3の画像 3
    • Remove the 2 philips screws
    • Remove the brackets on both sides with your tweezers.
  6. PlayStation 2 Slimline PVR-802W Laser Replacement, Remove silver rail: 手順 6、 3の画像 1 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove silver rail: 手順 6、 3の画像 2 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove silver rail: 手順 6、 3の画像 3
    • If you got the same results as in the 1st photo, then proceed.
    • Take the silver rail and push it out *carefully* from the track.
    • Take the silver rail with your tweezers and pull it towards yourself to take it out. Be carefull, as it still attached to the laser, just guide it slowly towards yourself.
  7. PlayStation 2 Slimline PVR-802W Laser Replacement, Remove laser: 手順 7、 3の画像 1 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove laser: 手順 7、 3の画像 2 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove laser: 手順 7、 3の画像 3
    • Take the laser with your hand, and till it like in the photo (to the back).
    • Open the ZIF connector. Be carefull not to break it, it can break easily. If you replace the laser, it won't matter, you can even practice how to open it and close it.
    • Take out the ribbon cable and remove the laser.
  8. PlayStation 2 Slimline PVR-802W Laser Replacement, Desoldering the anti-static security: 手順 8、 3の画像 1 PlayStation 2 Slimline PVR-802W Laser Replacement, Desoldering the anti-static security: 手順 8、 3の画像 2 PlayStation 2 Slimline PVR-802W Laser Replacement, Desoldering the anti-static security: 手順 8、 3の画像 3
    • It's important to remove the anti-static security, otherwise it won't work! Some lasers come without the anti-static security.
    • You need a soldering station to DESOLDER the anti-static (if it's there), without de-soldering it, the laser could be busted!!
    • Remove the anti-static security. Use some copper wick to remove the solder.
    • When it looks like in the 3rd photo, you are good to.
  9. PlayStation 2 Slimline PVR-802W Laser Replacement, Transfer holder: 手順 9、 3の画像 1 PlayStation 2 Slimline PVR-802W Laser Replacement, Transfer holder: 手順 9、 3の画像 2 PlayStation 2 Slimline PVR-802W Laser Replacement, Transfer holder: 手順 9、 3の画像 3
    • Remove the single philips screw.
    • Transfer the holder to the new laser and fasten it again with the philips screw.
  10. PlayStation 2 Slimline PVR-802W Laser Replacement, Place the new laser in: 手順 10、 3の画像 1 PlayStation 2 Slimline PVR-802W Laser Replacement, Place the new laser in: 手順 10、 3の画像 2 PlayStation 2 Slimline PVR-802W Laser Replacement, Place the new laser in: 手順 10、 3の画像 3
    • Take the new laser and open up the ZIF connector.
    • Place it back as shown in the 2nd photo.
    • Put everything back together. The 3rd picture show how it needs to be done!
終わりに
Do not forget to transfer the slider from the old laser to the new one!
15 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
koppie007
メンバー登録日: 08/22/13
11,902 ポイント
9のガイドは作成済み
チーム
Protectors Of The Game Systems Protectors Of The Game Systems人のメンバー
Community
4 メンバー
24のガイドは作成済み
5 件のコメント
Thank you for caring enough to show us how to do this and for your time. You are appreciated.
Mark Sawyers - 返信
Hi Mark! No problem at all, happy to hear that I'm able to help you :)!!
koppie007 -
Where do you recommend getting the actual part? Looking for a reliable seller
Parker Ludwig - 返信
I am also looking for the best quality part. If I am going through the trouble of disassembling everything then I want to make sure I have a durable replacement. Excellent guide!
Jeremy B -
Thanks! Well, I'm afraid that the only option is to buy this from a Chinese webshop (AliExpress as example). You can't buy it on Amazon (as far as I looked it up). And getting one from another console which is not opened yet (original) is probably at the end of it's life time. I have some experience with a Chinese one, and they do work great so far!
koppie007 -
コメントを追加
統計データ:
過去 24時間: 29
過去 7 日: 182
過去 30 日: 890
今までの合計 24,996
