メインコンテンツにスキップ
PlayStation 2 Slimline Optical Drive Replacement
必要な工具と部品
  1. PlayStation 2 Slimline Optical Drive Replacement, Outer Shell: 手順 1、 1の画像 1
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline Optical Drive Replacement: 手順 2、 3の画像 1 PlayStation 2 Slimline Optical Drive Replacement: 手順 2、 3の画像 2 PlayStation 2 Slimline Optical Drive Replacement: 手順 2、 3の画像 3
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline Optical Drive Replacement: 手順 3、 3の画像 1 PlayStation 2 Slimline Optical Drive Replacement: 手順 3、 3の画像 2 PlayStation 2 Slimline Optical Drive Replacement: 手順 3、 3の画像 3
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline Optical Drive Replacement: 手順 4、 3の画像 1 PlayStation 2 Slimline Optical Drive Replacement: 手順 4、 3の画像 2 PlayStation 2 Slimline Optical Drive Replacement: 手順 4、 3の画像 3
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: 手順 5、 2の画像 1 PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: 手順 5、 2の画像 2
    • Locate the optical drive which occupies most of the space on the right side of the unit. It can be identified by the four screws with wide-diameter heads fastening the optical drive to the motherboard.
  6. PlayStation 2 Slimline Optical Drive Replacement: 手順 6、 2の画像 1 PlayStation 2 Slimline Optical Drive Replacement: 手順 6、 2の画像 2
    • Remove the four 4.0 mm screws using a #1 Phillips screwdriver.
  7. PlayStation 2 Slimline Optical Drive Replacement: 手順 7、 1の画像 1
    • Locate the three ribbon cables connecting the optical drive to the motherboard.
  8. PlayStation 2 Slimline Optical Drive Replacement: 手順 8、 3の画像 1 PlayStation 2 Slimline Optical Drive Replacement: 手順 8、 3の画像 2 PlayStation 2 Slimline Optical Drive Replacement: 手順 8、 3の画像 3
    • Gently detach the ribbon cables from the motherboard using a pair of tweezers.
    • Note: The ribbon cable in the center must be unlocked by lifting up the black tab. Remember to push the tab down upon re-installation to secure the cable.
    • Caution: Always remove ribbon cables by the plastic handles located on each end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
  9. PlayStation 2 Slimline Optical Drive Replacement: 手順 9、 3の画像 1 PlayStation 2 Slimline Optical Drive Replacement: 手順 9、 3の画像 2 PlayStation 2 Slimline Optical Drive Replacement: 手順 9、 3の画像 3
    • Remove any tape fastening the cables to the motherboard and gently lift and remove the optical drive.
終わりに
24 の人々がこのガイドを完成させました。
Thomas Sullivan
メンバー登録日: 10/23/13
3,927 ポイント
6のガイドは作成済み
7 件のコメント
انا أريد للغة عربية
Muammar lmgaroush - 返信
you also must disconnect the ribbon cable from the laser assembly by flipping back the little brown lever and removing the cable. This frees the assembly from the rest of the console. To actually replace the drive, you need to move the lens away from the disc hub by gently turning the worm gear. Flip the new assembly over and connect the brown ribbon that is glued to the metal shield. DO NOT REMOVE THE GLUED RIBBON UNLESS YOU INTEND TO REPLACE IT. After that one is connected, you can slowly flip the assembly and rest is in place. Connect the other ribbons to their respective connectors. Return all the screws to their positions and tighten so they are firm. Don’t go overboard screwing them back in.
Rusty Shackleford - 返信
Hello is the optical drive from my ps2 70004 compatible in my ps2 slim 75001?
Jorick Earl Bastian - 返信
I don't see any reason why it shouldn't be.
LOLMAN 9538 (LOLMAN9538) -
This is a great instructional aside from one thing, if you don’t not have the tape/glue for the ribbon cable that goes under the assembly, do not remove that ribbon cable from the shell. just disconnect it from the assembly, and put it in the new assembly. I wish I had read the comments before I did this myself. Please add this to the notes for the instructional. Now one of my games are ruined, and I have to buy a new one.
Noah L - 返信
コメントを追加
統計データ:
過去 24時間: 17
過去 7 日: 77
過去 30 日: 419
今までの合計 24,371
