はじめに
In the need that you need to replace the entire disc drive, here's what you need to do. You may need to do a little eBay perusing first, but when you find that replacement, these steps will show you how to remove your old one.
パーツ
パーツは指定されていません。
ビデオの概要
Use the flat edge of a metal spudger to pry the eight flat screw covers out.
Remove the following eight screws securing the top cover to the bottom case:
Four 55.4 mm Philips screws
Four 18.0 mm Phillips screws
Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case.
Lift and remove the optical disc drive straight up out of the bottom case.
Underneath where the power supply once was is a transparent piece of plastic. This is the heat shield, and it can now be removed.
36 の人々がこのガイドを完成させました。
3 件のコメント
Thank for sharing the material! My PS was broken so I played visa casino for real money for some time. Now I replaced the Disc Drive but I still keep on playing for real money. So I play both. Life is great!
It helped out a lot I was able to fix my
What replacement drive would you recommend?
