Use your thumbs to pry the case apart.
It is easiest to pry the case apart if you start at the bottom.
The case should come apart with minimal effort. If it doesn't, you can use a spudger or plastic opening tool to pry it open.
While pulling the camera out of the case, note the small soft plastic cover on the side. This cover will detach from the rest of the device.
Once the bottom of the inner camera is pulled out, pull the device out completely.
Use a firm grasp when removing the device from the case for stability and control.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
