Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
The screw only needs to be turned a couple of times.
Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
Pry the board connection with the 2 black wires from the terminal.
BE CAREFUL: Do not pull hard by the wires or you may dislodge them from the connection instead of removing the connection from the board.
Pull out the wires through the opening in the top of the grip and replace the solenoid.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
