Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
The screw only needs to be turned a couple of times.
Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
Gently pull out the two eyes, one on each side of the paintball marker.
The red wire leading to the eye on the right side of the paintball marker. The black wire leads to the eye on the left side.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
