メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
The trigger on the Etha doesn't break often, but you may choose to replace it for a trigger you prefer or it may simply need cleaning.
パーツ
パーツは指定されていません。
  1. Use the 5/64" hex key to remove the screw shown. Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  2. Flip the marker over and use the 5/64" hex key to remove the screw shown.
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  3. Carefully remove the 9V battery and connector. Remove the 9V battery from the connector.
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  4. Use a hex key to unscrew the middle screw on the top of the trigger.
    • Use a hex key to unscrew the middle screw on the top of the trigger.
  5. Use same hex key to push through trigger retention pin on the side of the gun.
    • Use same hex key to push through trigger retention pin on the side of the gun.
  6. Pull out the trigger by grabbing the bottom and slowly rotating outwards. Pull out the trigger by grabbing the bottom and slowly rotating outwards.
    • Pull out the trigger by grabbing the bottom and slowly rotating outwards.
終わりに
ある他の人がこのガイドを完成しました。
Evan Hench
メンバー登録日: 2014年10月19日
211 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-42, Amido Fall 2014 Cal Poly, Team 10-42, Amido Fall 2014人のメンバー
CPSU-AMIDO-F14S10G42
5 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 656
