はじめに
Removing the grip panels allows you to change the battery and allows you to remove the frame, which gives access to more parts of the marker.
必要な工具と部品
Use the 5/64" hex key to remove the screw shown.
Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
