はじめに
Use this guide to replace the display screen of your Pipo S1 Tablet. Replacing the display screen is pretty simple by following the following steps and using iFixit tools.
必要な工具と部品
Insert an iFixit opening tool between the body and display of the tablet at the bottom of the device where the charging port is.
Slide the tool along the gap you are creating, moving to the right direction against the mini USB port.
On the bottom of your tablet, take your J000 screwdriver and take out the three 3mm screws that hold down the motherboard.
ある他の人がこのガイドを完成しました。
