メインコンテンツにスキップ
Pioneer Steel Wheels Swivels Replacement
必要な工具と部品
  1. Pioneer Steel Wheels Swivels Replacement, Folding Hinges: 手順 1、 2の画像 1 Pioneer Steel Wheels Swivels Replacement, Folding Hinges: 手順 1、 2の画像 2
    • While holding the base of the headband with one hand, hold the ear cup with the other hand.
    • Pull them apart to reveal the screw.
  2. Pioneer Steel Wheels Swivels Replacement: 手順 2、 2の画像 1 Pioneer Steel Wheels Swivels Replacement: 手順 2、 2の画像 2
    • While apart, remove the screw from the headphone.
  3. Pioneer Steel Wheels Swivels Replacement: 手順 3、 2の画像 1 Pioneer Steel Wheels Swivels Replacement: 手順 3、 2の画像 2
    • Loosen the plastic cover piece that protects the chrome folding hinge.
    • Remove the plastic cover piece.
    • During reassembly, make sure the plastic covering piece hooks onto the base of the chrome hinge before screwing it back in.
  4. Pioneer Steel Wheels Swivels Replacement: 手順 4、 2の画像 1 Pioneer Steel Wheels Swivels Replacement: 手順 4、 2の画像 2
    • Holding the ear cup with one hand, pull up on the base of the headband with the other hand to release the folding hinge.
    • Repeat for the opposite side if necessary.
  5. Pioneer Steel Wheels Swivels Replacement, Drivers: 手順 5、 2の画像 1 Pioneer Steel Wheels Swivels Replacement, Drivers: 手順 5、 2の画像 2
    • Remove the three screws located on the driver cover of the ear cup with the PH0 Phillips screw driver.
  6. Pioneer Steel Wheels Swivels Replacement: 手順 6、 2の画像 1 Pioneer Steel Wheels Swivels Replacement: 手順 6、 2の画像 2
    • Pull the driver cover away from the headphone.
    • Do not pull the driver cover away too fast since there are wires connecting the driver to the ear cup.
    • During reassembly, make sure the two wires are pointing downward before screwing the driver back in.
  7. Pioneer Steel Wheels Swivels Replacement, Swivels: 手順 7、 2の画像 1 Pioneer Steel Wheels Swivels Replacement, Swivels: 手順 7、 2の画像 2
    • Separate the swivel from the ear cup.
  8. Pioneer Steel Wheels Swivels Replacement: 手順 8、 3の画像 1 Pioneer Steel Wheels Swivels Replacement: 手順 8、 3の画像 2 Pioneer Steel Wheels Swivels Replacement: 手順 8、 3の画像 3
    • Grab the end of the swivel that is closest to "Pioneer" and pull outward.
  9. Pioneer Steel Wheels Swivels Replacement: 手順 9、 3の画像 1 Pioneer Steel Wheels Swivels Replacement: 手順 9、 3の画像 2 Pioneer Steel Wheels Swivels Replacement: 手順 9、 3の画像 3
    • Switch sides and grab the other end of the swivel and pull outward as well.
    • During reassembly, insert the swivel back at the tilted position so it can be popped in with ease.
終わりに
作成者
2人の作成者と共同で作成されました。
Garrett Leung
メンバー登録日: 04/16/13
979 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S10G40
4 メンバー
37のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 369
