メインコンテンツにスキップ
Pioneer Steel Wheels Folding Hinges Replacement
必要な工具と部品
  1. Pioneer Steel Wheels Folding Hinges Replacement, Headband: 手順 1、 2の画像 1 Pioneer Steel Wheels Folding Hinges Replacement, Headband: 手順 1、 2の画像 2
    • Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
  2. Pioneer Steel Wheels Folding Hinges Replacement: 手順 2、 2の画像 1 Pioneer Steel Wheels Folding Hinges Replacement: 手順 2、 2の画像 2
    • With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
    • With force, pull upwards.
  3. Pioneer Steel Wheels Folding Hinges Replacement: 手順 3、 3の画像 1 Pioneer Steel Wheels Folding Hinges Replacement: 手順 3、 3の画像 2 Pioneer Steel Wheels Folding Hinges Replacement: 手順 3、 3の画像 3
    • Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
    • Repeat on the opposite side and the headband will be released.
    • During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
  4. Pioneer Steel Wheels Folding Hinges Replacement, Folding Hinges: 手順 4、 2の画像 1 Pioneer Steel Wheels Folding Hinges Replacement, Folding Hinges: 手順 4、 2の画像 2
    • While holding the base of the headband with one hand, hold the ear cup with the other hand.
    • Pull them apart to reveal the screw.
  5. Pioneer Steel Wheels Folding Hinges Replacement: 手順 5、 2の画像 1 Pioneer Steel Wheels Folding Hinges Replacement: 手順 5、 2の画像 2
    • While apart, remove the screw from the headphone.
  6. Pioneer Steel Wheels Folding Hinges Replacement: 手順 6、 2の画像 1 Pioneer Steel Wheels Folding Hinges Replacement: 手順 6、 2の画像 2
    • Loosen the plastic cover piece that protects the chrome folding hinge.
    • Remove the plastic cover piece.
    • During reassembly, make sure the plastic covering piece hooks onto the base of the chrome hinge before screwing it back in.
  7. Pioneer Steel Wheels Folding Hinges Replacement: 手順 7、 2の画像 1 Pioneer Steel Wheels Folding Hinges Replacement: 手順 7、 2の画像 2
    • Holding the ear cup with one hand, pull up on the base of the headband with the other hand to release the folding hinge.
    • Repeat for the opposite side if necessary.
終わりに
作成者
2人の作成者と共同で作成されました。
Garrett Leung
メンバー登録日: 04/16/13
979 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S10G40
4 メンバー
37のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 20
今までの合計 541
