はじめに
This guide will show you the steps to remove the aluminum plates.
パーツ
パーツは必要ありません。
  1. Remove the two screws on the underside of the headband with the PH0 Phillips screw driver. Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
    • Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
  2. With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband. With force, pull upwards.
    • With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
    • With force, pull upwards.
  3. Remove the rail-piece that is now sticking up by pulling it up and out of the headphone. Repeat on the opposite side and the headband will be released. During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
    • Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
    • Repeat on the opposite side and the headband will be released.
    • During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. While holding the base of the ear cup with one hand, insert your index finger from your other hand into the inside of the foam ear piece. While holding the base of the ear cup with one hand, insert your index finger from your other hand into the inside of the foam ear piece.
    • While holding the base of the ear cup with one hand, insert your index finger from your other hand into the inside of the foam ear piece.
  6. With slight force, peel the foam ear pieces away from the ear cup. Make sure to pull out the foam ear pieces slowly. Pulling on them fast will tear the leather wrapping. Repeat for the opposite side if necessary.
    • With slight force, peel the foam ear pieces away from the ear cup.
    • Make sure to pull out the foam ear pieces slowly. Pulling on them fast will tear the leather wrapping.
    • Repeat for the opposite side if necessary.
  7. Remove the three screws located on the driver cover of the ear cup with the PH0 Phillips screw driver. Remove the three screws located on the driver cover of the ear cup with the PH0 Phillips screw driver.
    • Remove the three screws located on the driver cover of the ear cup with the PH0 Phillips screw driver.
  8. Pull the driver cover away from the headphone. Do not pull the driver cover away too fast since there are wires connecting the driver to the ear cup.
    • Pull the driver cover away from the headphone.
    • Do not pull the driver cover away too fast since there are wires connecting the driver to the ear cup.
    • During reassembly, make sure the two wires are pointing downward before screwing the driver back in.
  9. Remove the three screws located on the driver casing. Remove the three screws located on the driver casing. Remove the three screws located on the driver casing.
    • Remove the three screws located on the driver casing.
  10. With your thumb, push the middle of the aluminum piece outwards while holding the ear cup base with your other hand. During reassembly, make sure the aluminum plates line up with the holes for the screws. During reassembly, make sure the aluminum plates line up with the holes for the screws.
    • With your thumb, push the middle of the aluminum piece outwards while holding the ear cup base with your other hand.
    • During reassembly, make sure the aluminum plates line up with the holes for the screws.
まとめ
Garrett Leung
メンバー登録日: 2013年04月16日
883 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S10G40
4 メンバー
20のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 235
