メインコンテンツにスキップ
Pioneer R1 Touch Screen Replacement
必要な工具と部品
  1. Pioneer R1 Touch Screen Replacement, Touch Screen: 手順 1、 1の画像 1
    • Insert your plastic spudger in the opening near the HDMI port.
    • Gently pry the back cover of the R1 from the the front by using the spudger along the edges.
    • Do not pull the back cover straight off the R1 as components of the speakers will be attached to both sides.
  2. Pioneer R1 Touch Screen Replacement: 手順 2、 1の画像 1
    • Lay the R1 flat like an open book.
    • This will prevent the speakers from becoming disconnected from the motherboard.
  3. Pioneer R1 Touch Screen Replacement: 手順 3、 1の画像 1
    • Remove the tape that is holding the motherboard to the display and covering the cable attachments.
    • Peel back just the end of this tape to free the front facing camera.
  4. Pioneer R1 Touch Screen Replacement: 手順 4、 1の画像 1
    • Remove the three 4 mm screws along the base of the motherboard with a Phillips #00 Screwdriver.
  5. Pioneer R1 Touch Screen Replacement: 手順 5、 1の画像 1
    • Disengage the two cable locks using your spudger or your finger nail.
    • Slide the cable free from the disengaged lock.
    • Do not pull across the cables as this may tear and permanently damage it.
  6. Pioneer R1 Touch Screen Replacement: 手順 6、 2の画像 1 Pioneer R1 Touch Screen Replacement: 手順 6、 2の画像 2
    • Insert your spudger between the LCD display and the touch screen.
    • Gently pry the LCD display from the the touchscreen by using the spudger along the edges.
  7. Pioneer R1 Touch Screen Replacement: 手順 7、 1の画像 1
    • Once disengaged, remove the LCD display from the touchscreen.
終わりに
作成者
1人の作成者と共同作成されました。
Christopher Rosario
メンバー登録日: 02/17/15
411 ポイント
4のガイドは作成済み
チーム
San Diego State, Team 1-1, Sheppard Winter 2015 San Diego State, Team 1-1, Sheppard Winter 2015人のメンバー
SDSU-SHEPPARD-W15S1G1
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 23
今までの合計 2,612
