この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
A faulty USB port can cause the user unable to play media to the radio receiver. This guide will show you how to replace the USB port for the Pioneer FH-X730BS.
必要な工具と部品
Apply pressure to the tabs on each side using the plastic opening tool.
You will need to pull the face away from the frame while unhooking the tabs.
Here you are able to desolder the USB ports from the circuit board and solder a replacement USB port on.
もう少しです!
終わりに
