はじめに
A faulty auxiliary inlet can cause the user unable to play media to the radio receiver. This guide will show you how to replace the Auxiliary Inlet for the Pioneer FH-X730BS.
パーツ
パーツは必要ありません。
  1. Apply pressure to the tabs on each side using the plastic opening tool. You will need to pull the face away from the frame while unhooking the tabs. You will need to pull the face away from the frame while unhooking the tabs.
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. After removing the stereo face from the frame it should look similar to this. Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face. Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
    • After removing the stereo face from the frame it should look similar to this.
    • Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Remove the volume knob by pulling it towards you and pull the motherboard out of the face. The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons. You can now insert the replacement audio buttons into the face.
    • Remove the volume knob by pulling it towards you and pull the motherboard out of the face.
    • The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons.
    • You can now insert the replacement audio buttons into the face.
  5. Here you are able to desolder the auxiliary ports  from the circuit board and solder a replacement auxiliary port on.
    • Here you are able to desolder the auxiliary ports from the circuit board and solder a replacement auxiliary port on.
    • The end of the soldering iron will be hot.
まとめ
Cody Pesta
メンバー登録日: 2018年09月17日
667 ポイント
6のガイドは作成済み
チーム
Washington State, Team S2-G4, Hope Fall 2018 Washington State, Team S2-G4, Hope Fall 2018人のメンバー
WSU-HOPE-F18S2G4
3 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 36
