メインコンテンツにスキップ
Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement
必要な工具と部品
  1. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement, Control Panel Circuit Board: 手順 1、 1の画像 1
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
  2. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: 手順 2、 1の画像 1
    • Remove the two 6.5 mm Phillips screws on the back of the device casing.
  3. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: 手順 3、 1の画像 1
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
  4. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: 手順 4、 1の画像 1
    • Unlatch the three plastic connectors on the top of the receiver that hold the front panel to the device casing.
  5. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: 手順 5、 1の画像 1
    • The connectors on the bottom of the device may be very stiff and could require the use of a plastic prying tool.
    • Carefully flip the device over and unlatch the three plastic connectors that hold the front panel to the bottom of the device casing.
  6. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: 手順 6、 1の画像 1
    • Grip and unplug the ribbon connector that connects the front circuit board to the device.
  7. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: 手順 7、 1の画像 1
    • Unscrew the three 1/4 Phillips head screws on the back of the front circuit board.
  8. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: 手順 8、 2の画像 1 Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: 手順 8、 2の画像 2
    • Grip the circuit board and slide towards the front side of the plastic casing.
    • Lift upwards to remove the circuit board from the front panel.
終わりに
作成者
2人の作成者と共同で作成されました。
Cody Carter
メンバー登録日: 01/30/18
1,049 ポイント
6のガイドは作成済み
チーム
Baylor, Team S1-G5, Johnson Spring 2018 Baylor, Team S1-G5, Johnson Spring 2018人のメンバー
BU-JOHNSON-S18S1G5
3 メンバー
6のガイドは作成済み
0 Guide Comments
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 18
今までの合計 524
