メインコンテンツにスキップ
Photive Hydra Speaker Replacement
必要な工具と部品
  1. Photive Hydra  Speaker  Replacement, Face Plate and Back Plate: 手順 1、 1の画像 1
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
  2. Photive Hydra  Speaker  Replacement: 手順 2、 2の画像 1 Photive Hydra  Speaker  Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool to pry off the face plate.
  3. Photive Hydra  Speaker  Replacement: 手順 3、 1の画像 1
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
  4. Photive Hydra  Speaker  Replacement: 手順 4、 1の画像 1
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
  5. Photive Hydra  Speaker  Replacement: 手順 5、 2の画像 1 Photive Hydra  Speaker  Replacement: 手順 5、 2の画像 2
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
  6. Photive Hydra  Speaker  Replacement, Speaker: 手順 6、 2の画像 1 Photive Hydra  Speaker  Replacement, Speaker: 手順 6、 2の画像 2
    • Identify the two Phillips (Length-5/16" Head-1/8") screws holding the speaker in place and remove them.
  7. Photive Hydra  Speaker  Replacement: 手順 7、 1の画像 1
    • Remove the bracket holding the speaker in place.
  8. Photive Hydra  Speaker  Replacement: 手順 8、 1の画像 1
    • Disconnect the wires that are connected from the speaker to the motherboard.
  9. Photive Hydra  Speaker  Replacement: 手順 9、 3の画像 1 Photive Hydra  Speaker  Replacement: 手順 9、 3の画像 2 Photive Hydra  Speaker  Replacement: 手順 9、 3の画像 3
    • After all extra components are out of the way, you will need to remove the adhesive holding the speaker using either a heating gun or the iOpener kit (both can be purchased under the Parts and Tools Store section of the menu bar). Once that is completed, replace the broken speaker with the new, functional speaker.
  10. Photive Hydra  Speaker  Replacement: 手順 10、 2の画像 1 Photive Hydra  Speaker  Replacement: 手順 10、 2の画像 2
    • Identify the four Phillips (Length-5/16", Head-1/8") screws holding the speaker housing (below the battery) and remove them.
  11. Photive Hydra  Speaker  Replacement: 手順 11、 1の画像 1
    • Identify motherboard.
  12. Photive Hydra  Speaker  Replacement: 手順 12、 1の画像 1
    • Disconnect highlighted electrical cords.
  13. Photive Hydra  Speaker  Replacement: 手順 13、 1の画像 1
    • Disconnect second highlighted electrical cord.
  14. Photive Hydra  Speaker  Replacement: 手順 14、 1の画像 1
    • Pull motherboard up and away in order to remove it.
  15. Photive Hydra  Speaker  Replacement: 手順 15、 1の画像 1
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the speaker in place and remove them.
  16. Photive Hydra  Speaker  Replacement: 手順 16、 3の画像 1 Photive Hydra  Speaker  Replacement: 手順 16、 3の画像 2 Photive Hydra  Speaker  Replacement: 手順 16、 3の画像 3
    • Upon removing the plastic bracket, you will need to remove the adhesive using either a heating gun or the iOpener kit (both can be purchased under the Parts and Tools Store section of the menu bar) that is holding the speaker in place. Once that is completed, replace the broken speaker with a new, functional speaker.
終わりに
作成者
4人の作成者と共同で作成されました。
Andrew Chase
メンバー登録日: 02/09/16
352 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 11-3, Cheng Spring 2016 USF Tampa, Team 11-3, Cheng Spring 2016人のメンバー
USFT-CHENG-S16S11G3
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 776
