メインコンテンツにスキップ
Philips TAS7505 USB-A & USB-C port Replacement
必要な工具と部品
  1. Philips TAS7505 USB-A & USB-C port Replacement, Philips TAS7505 Outer Shell Disassembly: 手順 1、 2の画像 1 Philips TAS7505 USB-A & USB-C port Replacement, Philips TAS7505 Outer Shell Disassembly: 手順 1、 2の画像 2
    • Make sure the speaker is turned off before you begin the disassembly.
    • Turn the speaker upside down. You will see a rubber base. Use an opening tool to lift up the sides to expose the screws.
  2. Philips TAS7505 USB-A & USB-C port Replacement: 手順 2、 3の画像 1 Philips TAS7505 USB-A & USB-C port Replacement: 手順 2、 3の画像 2 Philips TAS7505 USB-A & USB-C port Replacement: 手順 2、 3の画像 3
    • There will be 4 exposed screws. Make sure to use the Phillips #0 Screwdriver.
    • When the screws are removed, you can use an opening tool to take off the plastic cover.
  3. Philips TAS7505 USB-A & USB-C port Replacement: 手順 3、 3の画像 1 Philips TAS7505 USB-A & USB-C port Replacement: 手順 3、 3の画像 2 Philips TAS7505 USB-A & USB-C port Replacement: 手順 3、 3の画像 3
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with a Philips #0 screwdriver.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 USB-A & USB-C port Replacement: 手順 4、 3の画像 1 Philips TAS7505 USB-A & USB-C port Replacement: 手順 4、 3の画像 2 Philips TAS7505 USB-A & USB-C port Replacement: 手順 4、 3の画像 3
    • You can now see the inside of the speaker but you aren't done yet.
    • Remove both rubber stands that hold up the device horizontally (one of these stands is a cover for the USB ports).
  5. Philips TAS7505 USB-A & USB-C port Replacement: 手順 5、 1の画像 1
    • Once you pull these out, you can pull the whole sleeve to expose the infrastructure of the device.
  6. Philips TAS7505 USB-A & USB-C port Replacement, USB-A & USB-C port: 手順 6、 1の画像 1
    • Use the Phillips #0 Screwdriver to remove all 6 screws.
  7. Philips TAS7505 USB-A & USB-C port Replacement: 手順 7、 1の画像 1
    • Before pulling the USB port box out, disconnected the power connector from the motherboard.
    • Carefully pull out the USB port box
終わりに
作成者
3人の作成者と共同で作成されました。
Yamilena Hernandez
メンバー登録日: 09/26/22
135 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 5-2, Adachi Fall 2022 CSU Los Angeles, Team 5-2, Adachi Fall 2022人のメンバー
CSULA-ADACHI-F22S5G2
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 144
