メインコンテンツにスキップ
Philips TAS7505 Speaker Replacement
必要な工具と部品
  1. Philips TAS7505 Speaker Replacement, Speaker: 手順 1、 3の画像 1 Philips TAS7505 Speaker Replacement, Speaker: 手順 1、 3の画像 2 Philips TAS7505 Speaker Replacement, Speaker: 手順 1、 3の画像 3
    • Using the opening tool, remove the rubber padding from the bottom of the speaker.
    • The rubber padding is glued on and may require reapplying adhesive to re-assemble.
  2. Philips TAS7505 Speaker Replacement: 手順 2、 3の画像 1 Philips TAS7505 Speaker Replacement: 手順 2、 3の画像 2 Philips TAS7505 Speaker Replacement: 手順 2、 3の画像 3
    • Using the Philips screwdriver head #0, remove all four screws holding the plastic plate in place.
    • Use the same opening tool from the previous step to remove the plastic plate.
  3. Philips TAS7505 Speaker Replacement: 手順 3、 3の画像 1 Philips TAS7505 Speaker Replacement: 手順 3、 3の画像 2 Philips TAS7505 Speaker Replacement: 手順 3、 3の画像 3
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with the Philips 0-bit screwdriver bit.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 Speaker Replacement: 手順 4、 3の画像 1 Philips TAS7505 Speaker Replacement: 手順 4、 3の画像 2 Philips TAS7505 Speaker Replacement: 手順 4、 3の画像 3
    • Squeeze the white connector on the bottom to release a clip that is hidden from sight. This will allow it to be wiggled free.
    • Remove the battery from the speaker by disconnecting the white connector from the motherboard.
  5. Philips TAS7505 Speaker Replacement: 手順 5、 3の画像 1 Philips TAS7505 Speaker Replacement: 手順 5、 3の画像 2 Philips TAS7505 Speaker Replacement: 手順 5、 3の画像 3
    • Find the rubber flap that covers the USB-A and USB-C port
    • Pull on the rubber flap, it should come out whole as shown in the second image
    • Once taken out the rubber flap, pull the interior of the speaker
  6. Philips TAS7505 Speaker Replacement: 手順 6、 2の画像 1 Philips TAS7505 Speaker Replacement: 手順 6、 2の画像 2
    • Once you have the speaker body out, unscrew the four screws holding the speaker down
    • Use Philips screwdriver head #0
  7. Philips TAS7505 Speaker Replacement: 手順 7、 1の画像 1
    • Pull the motherboard out then disconnect the white connector of the speaker by wiggling it back and forth.
    • See the motherboard repair guide for more in-depth instructions on this part
  8. Philips TAS7505 Speaker Replacement: 手順 8、 3の画像 1 Philips TAS7505 Speaker Replacement: 手順 8、 3の画像 2 Philips TAS7505 Speaker Replacement: 手順 8、 3の画像 3
    • The speaker will look like this if you have followed the steps correctly
終わりに
作成者
5人の作成者と共同で作成されました。
Frederick Jimenez
メンバー登録日: 09/26/22
277 ポイント
2のガイドは作成済み
チーム
CSU Los Angeles, Team 5-2, Adachi Fall 2022 CSU Los Angeles, Team 5-2, Adachi Fall 2022人のメンバー
CSULA-ADACHI-F22S5G2
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 28
今までの合計 603
