メインコンテンツにスキップ
Philips TAS7505 Motherboard Replacement
必要な工具と部品
  1. Philips TAS7505 Motherboard Replacement, Philips TAS7505 Outer Shell Disassembly: 手順 1、 2の画像 1 Philips TAS7505 Motherboard Replacement, Philips TAS7505 Outer Shell Disassembly: 手順 1、 2の画像 2
    • Make sure the speaker is turned off before you begin the disassembly.
    • Turn the speaker upside down. You will see a rubber base. Use an opening tool to lift up the sides to expose the screws.
  2. Philips TAS7505 Motherboard Replacement: 手順 2、 3の画像 1 Philips TAS7505 Motherboard Replacement: 手順 2、 3の画像 2 Philips TAS7505 Motherboard Replacement: 手順 2、 3の画像 3
    • There will be 4 exposed screws. Make sure to use the Phillips #0 Screwdriver.
    • When the screws are removed, you can use an opening tool to take off the plastic cover.
  3. Philips TAS7505 Motherboard Replacement: 手順 3、 3の画像 1 Philips TAS7505 Motherboard Replacement: 手順 3、 3の画像 2 Philips TAS7505 Motherboard Replacement: 手順 3、 3の画像 3
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with a Philips #0 screwdriver.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 Motherboard Replacement: 手順 4、 3の画像 1 Philips TAS7505 Motherboard Replacement: 手順 4、 3の画像 2 Philips TAS7505 Motherboard Replacement: 手順 4、 3の画像 3
    • You can now see the inside of the speaker but you aren't done yet.
    • Remove both rubber stands that hold up the device horizontally (one of these stands is a cover for the USB ports).
  5. Philips TAS7505 Motherboard Replacement: 手順 5、 1の画像 1
    • Once you pull these out, you can pull the whole sleeve to expose the infrastructure of the device.
  6. Philips TAS7505 Motherboard Replacement, Motherboard: 手順 6、 3の画像 1 Philips TAS7505 Motherboard Replacement, Motherboard: 手順 6、 3の画像 2 Philips TAS7505 Motherboard Replacement, Motherboard: 手順 6、 3の画像 3
    • Disconnect the battery from the motherboard by unclipping it from the side not visible to you
    • If you are having difficulties disconnecting the battery you can pull the battery out whole in order to get a better angle to disconnect it
  7. Philips TAS7505 Motherboard Replacement: 手順 7、 1の画像 1
    • Pull out the motherboard then disconnect the USB-A & USB-C port by pressing the clip
  8. Philips TAS7505 Motherboard Replacement: 手順 8、 2の画像 1 Philips TAS7505 Motherboard Replacement: 手順 8、 2の画像 2
    • Next is to disconnect the speaker
    • pull the motherboard out as much as you can and then wiggle the white box back and forth to get it out
  9. Philips TAS7505 Motherboard Replacement: 手順 9、 2の画像 1 Philips TAS7505 Motherboard Replacement: 手順 9、 2の画像 2
    この手順で使用する道具:
    購入する
    • Simply remove this white strand with a pair of tweezers.
  10. Philips TAS7505 Motherboard Replacement: 手順 10、 2の画像 1 Philips TAS7505 Motherboard Replacement: 手順 10、 2の画像 2
    • This is how the motherboard should be after doing all the steps correctly.
終わりに
作成者
3人の作成者と共同で作成されました。
Alejandro
メンバー登録日: 09/26/22
121 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 5-2, Adachi Fall 2022 CSU Los Angeles, Team 5-2, Adachi Fall 2022人のメンバー
CSULA-ADACHI-F22S5G2
5 メンバー
5のガイドは作成済み
コメント 1 件
The guides are very detailed with many steps and are easy to follow. It looks professional and well-made. Thank you for your contribution to Ifixit!
Dat Nguyen - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 229
